How to use Netsight to backup Extreme switch configurations?
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
Am using Netsight to backup the Extreme switch configuration. I have 100 switches in my network. Kindly help me with the steps to backup from netsight.
Photo of Dineshkumar Ramasamy
  • 430 Points 250 badge 2x thumb
  • so sad
Posted 2 years ago
Photo of Drew C.
Drew C., Community Manager
  • 37,336 Points 20k badge 2x thumb
Hi Dineshkumar, I've updated the title of this conversation to help clarify your question.  I hope you don't mind.
That said, take a look at this article in GTAC Knowledge: How to create a backup archive in Inventory Manager
(Edited)
I have did all that but am getting this error in all my devides
Can you please help me to resolve from this.
Photo of Drew C.
  • 36,968 Points 20k badge 2x thumb
Thanks Drew.
Let me try this today.
I am getting error as " Configuration file is empty". In all the switch am using VR-Mgmt.
Even when i use the below manual script in all the switch it is working.
"tftp put 10.102.9.102 vr "VR-Mgmt" primary.cfg 10_102_9_248_primary.cfg"
In this below script let me know which one i have to edit:
VR_VAR.Default=VR-Mgmt
PUT_FILE_CMD.Default=tftp %TFTP_IP% -v "%VR_VAR%" -p -l %LOCAL_FILE_NAME% -r %REMOTE_FILE_NAME%
GET_FILE_CMD.Default=tftp %TFTP_IP% -v "%VR_VAR%" -g -l %LOCAL_FILE_NAME% -r %REMOTE_FILE_NAME%
RESTORE_PRIMARY_CMD.Default=tftp get %TFTP_IP% vr "%VR_VAR%" %RELATIVE_TARGET_FILE_PATH% primary.cfg force-overwrite
Kindly help in this script please
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,086 Points 20k badge 2x thumb
Could you please provide a screenshot of the following two windows.
- in Inventory manager select one of the X-switches - I'd like to see the info in the right "general" tab
- then select the "image information" tab and post that also
- Netsight version
- is 10.102.9.102 the IP of the Netsight server
 - 6.3.0.179 version
- yes it is the IP of the netsight server and inside the netsight server am running TFTP server too. so that is the IP of both netsight and TFTP.
The setup looks exactly like mine and I have no problem to backup my X440.
I'd upgrade to version 7 if that is possible.
Thanks to Drew and Ronald.
Everything is good now after doing the below steps.
1. Open Inventory Manager.
2. Highlight the switch and then change to the Image Information tab on the right.
3. Select the original ExtremeXOS TFTP script from the MIBs and Script Overrides section.
4. Click the View button.
5. Copy the script and paste it into a new text file.
6. Change the name and description at the top of the script.
7. Change the @receive 5 to @receive 15 in the configuration archive section
8. Save it to the NetSight server in  /NetSight_Instal_path/NetSight/appdata/InventoryMgr/properties/devicefiles
9.  Select this new script for the Configuration MIB section of the MIB and Script Overrides.
10.  Click the Save button in the upper right.
Photo of Drew C.
  • 37,158 Points 20k badge 2x thumb
Great!  Glad Ron and I were able to help!
Thanks for sharing the steps you took to resolve it.
