Any idea how to backup a WM3700 Wireless Controller?
  • Question
  • Updated 3 years ago
  • Answered
Does anyone know how to save a backup config for the WM3700 Wireless Controller? I have read through the online manual and can't seem to find anything about this.
We had our controller lock up today, which required a power cycle to get everything back up and running. Makes me a bit nervous not having any sort of contingency plan in case this thing takes a dive.
Photo of Tyler Green
Tyler Green
  • 132 Points 100 badge 2x thumb
Posted 3 years ago
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,382 Points 4k badge 2x thumb
use copy command
copy running-config startup-config
copy running-config tftp:
try the above options .
Cli is same as cisco commands
Photo of David Rahn
David Rahn
  • 974 Points 500 badge 2x thumb
click the Statistics Tab
drill down till you see your controller ( mine is under System then under default )
pull down the little arrow on the right of the controller name
show startup config
from the new popup you can export the config to a tftp server,
or copy and past it to a file...
or log in the the cli with an ssh client and use a Cisco-like command
all one line:
copy startup-config tftp://<Ipaddress&gt;
Dave
Tyler Green
Thanks for the help Dave, this is exactly what I was looking for.
Photo of Taykin Izzet
Taykin Izzet , Employee
  • 2,924 Points 2k badge 2x thumb
Additionally, in the GUI, the same can be done by using the pull down menu and selecting 'Show Running Config' or 'Show Startup Config'. You can either copy the config as text or export the config using the preferred protocol.
(Edited)
Tyler Green
Thanks for the help Taykin, this is exactly what I was looking for.
