Any incompatibility switch A2H124-24P, with some micro controller Ethernet.
  • Question
  • Updated 4 years ago
I need to know if there is any incompatibility switch A2H124-24P, with some micro controller Ethernet? More specifically W5200
Photo of Gabriel
Gabriel
  • 82 Points 75 badge 2x thumb
Posted 4 years ago
Photo of Jason
Jason, Employee
  • 294 Points 250 badge 2x thumb
Gabriel,
What type of issues are you having?
Could you start by checking the command
show port advertise port#
See if these are the results you are expecting.
You may even want to try the command to see if there is a neg issue.
clear port advertise ge.x.x
1000t                    Advertises 1000BASE-T half duplex mode.
1000tfd                  Advertises 1000BASE-T full duplex mode.
100tx                    Advertises 100BASE-TX half duplex mode.
100txfd                  Advertises 100BASE-TX full duplex mode.
10t                      Advertises 10BASE-T half duplex mode.
10tfd                    Advertises 10BASE-T full duplex mode.
<cr>
pause                    Advertises PAUSE for full-duplex links.
Jason
Photo of Gabriel
Gabriel
Jason, Thanks for the prompt reply.
I have an apparatus that uses the Ethernet controller W5200. To release a port on the switch to connect that device it simply is not recognized. I tried on other Cisco switches, for example, and had no problem.
Here's a link with information on the ETH Controller:
http://www.parallax.com/sites/default/files/downloads/40002-W5200-Datasheet.pdf
