AP 3825 and MLAG Topology
  • Question
  • Updated 2 years ago
  • Answered
Hi everyone!
Is it possible to perform an MLAG connection between two Summit Switches and 3825i APs?
Our intention is to provide POE and LAG functionality simultaneously to the AP.
Thanks in advance.
Regards,
Alex.
Photo of Alex
Alex
  • 408 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Matthew Helm
Matthew Helm, Employee
  • 1,852 Points 1k badge 2x thumb
Haven't tried this, but I would expect the MLAG/LACP portion to work. However, I'm not sure about the PoE redundancy. See this: https://gtacknowledge.extremenetworks.com/articles/Solution/AP3825-cannot-be-powered-when-connecting...
Hope it helps.
Photo of Umut Aydin
Umut Aydin, Escalation Support Engineer
  • 2,110 Points 2k badge 2x thumb
MLAG is used on the switch.The AP will use LACP and POE should work as well.
Photo of Paul Russo
Paul Russo, Alum
  • 9,694 Points 5k badge 2x thumb
Hey Alex
MLAG is the function of the switches so any device that can do a LAG connection can be connected to XOS switches running MLAG.
P
Photo of Alex
Alex
Hi everyone!
So using MLAG we will be able to provide POE redundancy and LAG functionality simultaneously, right?
Regards,
Alex.
Photo of Umut Aydin
If both connection ends up on different switches ...yes for sure. If the ports ends on the same switch it's depend on the switch type. See the kb.
regards
Umut
Photo of Aguilar, William
Aguilar, William, Official Rep
  • 2,664 Points 2k badge 2x thumb
As far as PoE redundancy is concerned, the 3825 supports redundant PoE power but the AP will reboot if it loses power on the primary port and will come back up on the secondary port.  Alternative it can support transparent power failover with an external power supply.  For the sake of completeness the 3935 does support hitless PoE failover.
Thanks,
Will
