AP-650 (AP4610) update firmware manual
Junio_Calú
New Contributor II
How do I manually update the AP 4610 firmware? I'm having a version incompatibility issue, from the controller to the AP. The AP is in the version of Wing 5.2.xx the controller in the version "WM3600 5.5.0.0-090R". Giving a "show adoption status" I received "version-mismatch" in ap incompativel.
5 REPLIES 5
Bin
Hi Junio,
731c083233164ea5ba9833e17ec18ba5_RackMultipart20180201-40392-se5zzz-ReleaseNote_inline.png
If you need the release note, please email me - bhan@extremenetworks.com
Vedran_Jurak
New Contributor II
What is the exact 5.2.x.x version running on the AP650?
Thank you for response
You need to upgrade it to 5.2.13 or 5.4.x before upgrading to 5.5.
I suggest contacting the GTAC. They should be able to send you the proper firmware image.
