AP 6532 Led Indicators
  • Problem
  • Updated 8 months ago
  • Solved
Hi, I have 2 6532 APps that were working without a problem, now they are not responding, i reboot them and they doesn't come up, the LED Indicators are Solid Green and never change this State.
¿What can i do?, they dont have an console port.
Photo of Leonardo Fernandez
Leonardo Fernandez
  • 80 Points 75 badge 2x thumb
Posted 8 months ago
Photo of Edmundo Bermudez
Edmundo Bermudez
  • 498 Points 250 badge 2x thumb
Hi Leonardo
This status indicates that the equipment is in the process of system booting
Did you try updating the Firmware?
Do you have controller?
Leonardo Fernandez
Hi Edmundo, thanks for your response.
The leds are always on, they never change,
Its Strange because it was working, and suddenly 2 AP stoped respoding ping and then a third, when rebooted the Leds dont change.
I have 4 AP 6532 and one of them is the virtual controller of all of them, at first i thought it was an Hardware issue, now i think it could be and problem with the virtual controller.
I dont have a lot of experience with this AP with a virtual controller among them.
Photo of JESUS REYES DIAZ
JESUS REYES DIAZ
  • 222 Points 100 badge 2x thumb
you   can see  the  AP   with apdiscover  tool?
Photo of Ondrej Lepa
Ondrej Lepa, Employee
  • 5,116 Points 5k badge 2x thumb
Hello Leonardo,
See an article here:
What does LED blinking means on AP650?
As per the description you might be experiencing bootup or memory corruption issues.
Please consider raising a support case or RMA to get your APs replaced.
Regards,
Ondrej
Photo of Bin
Bin, Employee
  • 5,350 Points 5k badge 2x thumb
Hello Leonardo,
Here is one article about how to submit an RMA case.
Submit an RMA Case on the Extreme Portal
https://gtacknowledge.extremenetworks.com/articles/How_To/Submit-RMA-via-New-Support-Portal
Regards,
Bin
Edmundo Bermudez
You can enter via CLI to the Virtual Controller and send the following information:
show boot
 show adoption history
show adoption status
