AP 8533 Continuously Restarting? How to slove this?. AP firmware is 5.9.1.0-029R
  • 2
  • Question
  • Updated 4 weeks ago
  • Answered
Photo of Saravanamurthy K
Saravanamurthy K
  • 966 Points 500 badge 2x thumb
Posted 9 months ago
  • 2
Photo of Andy Holden
Andy Holden, Employee
  • 1,492 Points 1k badge 2x thumb
Hi
Reset the AP to factory defaults see if that clears the problem.
If using a power injector, try a different one
If using POE, change the Port.
Confirm wiring has not been damaged.
RMA the AP
Photo of Robert Zarzycki
Robert Zarzycki, Employee
  • 5,408 Points 5k badge 2x thumb
Photo of Christoph S.
Christoph S., Employee
  • 3,684 Points 3k badge 2x thumb
Does the unit boot up all the way and then randomly reboot or is it stuck in a boot loop with no possibility of pausing it? If it's the latter then it may need to be RMA'd.
(Edited)
Photo of Alona
Alona, Employee
  • 1,770 Points 1k badge 2x thumb
If AP 8533 reboot continously - that means one of the radios have failing to come up. You will have to RMA the unit and get a replacement.
Photo of Bin
Bin, Employee
  • 5,374 Points 5k badge 2x thumb
Photo of Rick Zhang
Rick Zhang
  • 60 Points
We have several locations that have 4 AP8533 now down to 1 working unit. The other 3 keep restarting. Bad product.
Photo of Tomasz
Tomasz
  • 1,768 Points 1k badge 2x thumb
What did you do to troubleshoot? What are the other symptoms? Where there any changes in your network config/applications or WiNG configuration/upgrade just before it started? Did you call GTAC?
