AP antenna orientation
Ronald_Dvorak
Honored Contributor
I've tried to find a document that descibe the antenna orientation for APs with external antennas but didn't find one so I'd like to know how you do it in your installations.
So how do you orientate the small omni antennas for a AP with 6 antennas like the. AP3825e or with 8 antennas like the AP3935e.
Do you orientate them all in the same direction or x/y/z axis if you've 3 per radio.
-Ron
9 REPLIES 9
Tuan_Nguyen
New Contributor II
I use 3 antennas Omi 2.4 same time, Is there anything better?
Timo1
New Contributor II
You just get a very short distance.
Drew_C
Valued Contributor III
This can also be bad for the radio. The antenna has to be matched to the frequency range the radio is transmitting on.
Tuan_Nguyen
New Contributor II
What happen if I plugged in Anten 5Ghz to port 2.4Ghz?
