AP Current Tx Power Level OFF
  • Problem
  • Updated 2 years ago
  • Solved
Hi! I'm having a problem related to the transmit power of radio 1 in the V2110 controller. I've entered the correct license but as I can see, I can't get the band of 5 GHz working, even though I've tried changing the channel used, the maximum transmission power and changing the country in the AP configuration screen several times. It always stays as <Off>. I've also rebooted the AP from the Bulk Configuration tab. Right now it's radio 2 working with multiple SSIDS.
Thanks in advance!
Photo of Juan Battaglino
Juan Battaglino
  • 276 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,192 Points 20k badge 2x thumb
What model access point?
Photo of Doug Hyde
If they are that model I would suggest contacting the GTAC so we can review the ap trace log packages to see why it's not coming online.
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
Use the Static Configuration on the AP tab when editing an AP to get it's IP address.  SSH to the IP address it reports under static config (admin, new2day) and do a cget config.
Paste the output of that here.
(Edited)
Juan Battaglino
# cget configReboot is needed due to config change: FALSE
AP authentication is needed due to config change: FALSE
sysName "AP3825i"
acSiteName ""
lastAcIp 192.168.250.3
#site cfg:
site disabled
dhcp lease 36000(s)
dhcp lease time renewal 72028 left 34993(s)
wipsMode 0
Real capture off
timeServer
LEDMode Normal
macFilterMode Deny
AP ThirdPartyMode 0
AP TunnelMode 1
Wassp VlanVid: -1
countryCode 999
broadcastDisassociation 0
modePersistence 0
linkPersistence 1
pollTimeout 15000
pollInterval 3000
ssh mode enable (1)
ssh timeout 180
password $1$.bwL4$Own82WonXWgXrcl89e7aQ1
slpuRetry 3
slpuTimeout 3
dnsRetry 3
dnsTimeout 3
slpmRetry 3
slpmTimeout 3
globalRetry 3
globalTimeout 3
LLDP disable  (0), TimeToLive:120,AnnouncementIntervall:30,AnnouncementDelay:2
logAlarm severity major (4)
apName 14162417085A0000
hostName AP3825i-14162417085A0000
apDesc
Ethernet(Phy): Speed:100  Duplex:full  Auto:on  Link:on
Ethernet (apcfg): Speed auto
dhcp mode enable (1)
ip 192.168.250.14
mask 255.255.255.0
gateway 192.168.250.1
eth0 MAC 20:B3:99:D7:57:94
Static MTU 1500
Jumbo Frame: Disabled
MIC Error Threshold 2
IASDNSPrefix 1
airfairLevel 4
radio 0 antennaType left 0x0 middle 0x0 right 0x0
radio 1 antennaType left 0x0 middle 0x0 right 0x0
radio 2 antennaType left 0x0 middle 0x0 right 0x0
outDoorChan 0
High Throughput HT capability for WEP and TKIP is disable (0)
Sending HT on all Probe Response is disable (0)
lbsSrcIp 0.0.0.0
lbsSrcPort 1144
lbsDstIp 0.0.0.0
lbsDstPort 0
lbsMcast 00:00:00:00:00:00
lbsTagMode 2
SNMP SERVER ENABLE disable
interAPRoam 0
clusterEncryption 1
clusterPassword GxxwgzAt
Band Preference Admin Disabled (raw bitmap 0 0 ) Oper Disabled
radioPreferenceTimeout 300
bandPreferenceAssocThreshold 0
bandPreferenceAssocPeriod 0
AC Mgmt Mac Addr 00:15:5d:00:02:2d
Mesh RSSI Sample Window integer of power 2 3
Mesh Link Quality Check Timer 1
Mesh Stability Factor 20
isMesh 0
Sniffer radio bitmap 0x0
AP role 0
Dual eth wired0 Admin DOWN Oper DOWN
Dual eth wired1 Admin UP Oper UP act
Lag: 0
Multicast Assembly: Disabled
Location Service: Disabled
Location Auto Collect: Disabled
Location Ondemand MAC List is empty, 0 MAC addresses
FixedAppPolicy Table: appId 1 numFields 1
FixedAppPolicy Table: appId 1 index 0 offset 0x0 mask 0x8000 val 0x0
FixedAppPolicy Table: appId 2 numFields 1
FixedAppPolicy Table: appId 2 index 0 offset 0x0 mask 0x8000 val 0x8000
FixedAppPolicy Table: appId 3 numFields 2
FixedAppPolicy Table: appId 3 index 0 offset 0x0 0x1 mask 0xffffffff 0xffffffff val 0x4d2d5345 0x415                         24348
FixedAppPolicy Table: appId 4 numFields 2
FixedAppPolicy Table: appId 4 index 0 offset 0x0 0x1 mask 0xffffffff 0xffff0000 val 0x4e4f5449 0x465                         90000
FixedAppPolicy Table: appId 5 numFields 1
FixedAppPolicy Table: appId 5 index 0 offset 0x0 mask 0xffffffff val 0x0
FixedAppPolicy Table: appId 6 numFields 1
FixedAppPolicy Table: appId 6 index 0 offset 0x0 mask 0xffffffff val 0x8400
# Radio 0
bssid 20:b3:99:d9:f5:40
frequency 0 0
beaconInterval 0 100
dtim 0 5
rtsThreshold 0 2346
fragThreshold 0 2346
preamble 0 long (2)
minPower 0 5
maxPower 0 5
atpcProcessInterval 0 0
atpcAdjPower 0 0
acsRfDomain 0 MyDomain
acsAllowedChListType 0 1
acsAllowedChList 0 is empty
dcsMode 0 off (0)
interfWaitTime 0 10
dcsNoiseThreshold 0 -80
dcsChannelOccupancyThreshold 0 100
dcsUpdatePeriod 0 5
interference 0 0
gProtMode 0 auto (2)
gProtType 0 cts-only (1)
gProtRate 0 11 (3)
wirelessMode 0 ac (12)
nChannelBonding 0 none (0)
nChannelWidth 0 20Mhz (1)
nGuardInterval 0 long (2)
nProtMode 0 none (0)
nProtType 0 cts-only (1)
nExtChanThreshold 0 50
aggrMsdu 0 disable (0)
aggrMsduMaxLen 0 4096
aggrMpdu 0 disable (0)
aggrMpduMaxLen 0 1048575
aggrMpduMaxFrames 0 64
addbaSupportEnabled 0 disable (0)
antConfig 0 7
antennaPortAtt 0 0[dB]
nonUnicastQuota 0 100
maxDistance 100
loadGroupId 0
loadBalancing 0 Disabled (raw bitmap 0)
loadControl 0 Disabled (raw bitmap 0)
clientCountLimit 0 112
rlcAssocTryMax 0 1
rlcAssocTryTimeout 0 300
minBasicRate 0 6
radioEnable 0 0
ldpcEnable 0 0
txstbcEnable 0 0
rxstbcEnable 0 0
txbfEnable 0 0
txbfClientLimit 0 16
adaptableRateForMcast disable (0)
mcastToUcastDelivery disable (0)
optMcastPS disable (0)
# Radio 1
bssid 20:b3:99:d9:f5:48
frequency 1 2437
beaconInterval 1 100
dtim 1 5
rtsThreshold 1 2346
fragThreshold 1 2346
preamble 1 long (2)
minPower 1 0
maxPower 1 11
atpcProcessInterval 1 0
atpcAdjPower 1 0
acsRfDomain 1 MyDomain
acsAllowedChListType 1 1
acsAllowedChList 1 2437,2462
dcsMode 1 off (0)
interfWaitTime 1 10
dcsNoiseThreshold 1 -80
dcsChannelOccupancyThreshold 1 100
dcsUpdatePeriod 1 5
interference 1 0
gProtMode 1 auto (2)
gProtType 1 cts-only (1)
gProtRate 1 11 (3)
wirelessMode 1 bg (3)
nChannelBonding 1 none (0)
nChannelWidth 1 20Mhz (1)
nGuardInterval 1 long (2)
nProtMode 1 none (0)
nProtType 1 cts-only (1)
nExtChanThreshold 1 50
aggrMsdu 1 disable (0)
aggrMsduMaxLen 1 4096
aggrMpdu 1 disable (0)
aggrMpduMaxLen 1 65535
aggrMpduMaxFrames 1 64
addbaSupportEnabled 1 disable (0)
antConfig 1 7
antennaPortAtt 1 0[dB]
nonUnicastQuota 1 100
maxDistance 100
loadGroupId 1
loadBalancing 1 Disabled (raw bitmap 0)
loadControl 1 Disabled (raw bitmap 0)
clientCountLimit 1 112
rlcAssocTryMax 1 1
rlcAssocTryTimeout 1 300
minBasicRate 1 1
radioEnable 1 1
ldpcEnable 1 0
txstbcEnable 1 0
rxstbcEnable 1 0
txbfEnable 1 0
txbfClientLimit 1 16
# Radio 0 Vns 1
vapSsid 0:1 "fnguest"
vapSessionAvailability 0:1 disable(0)
dot11e 0:1 disable (0)
dot11h 0:1 disable (0)
dot11hPowerBackOff 0:1 disable (0)
qosOverrideBssParam 0:1 0
qosOverrideDscp 0:1 0
vapVidAc 0:1 2
vapMode 0:1 tunnel (0)
vapVlanId 0:1 24585
vapTopoKey2Pvid 0:1 0
vapWmm 0:1 enable (1)
vapCcmpReplayIgnore 0:1 disable (0)
vapSuppressSsid 0:1 disable (0)
vapPrivacy 0:1 WPA2-PSK (7)
vapWepAAA 0:1 disable (0)
vapWpa 0:1 disable (0)
vapWpa2 0:1 enable (1)
vapWepSlotIndex 0:1 0
uapsd 0:1 0
vapKey 0:1
vapPassphraseIndex 0:1 1
vapPassphrase 0:1 ascii "argeNtina2014" hex "(null)"
vapGroupKeyInterval 0:1 3600
vapSlowPtkTimeout 0:1 disable (0)
vapOkc 0:1 preauth-only (2)
vapOkcRetry 0:1 2
vapOkcTimeout 0:1 1
vlanUPOverrideFlag 0:1 0
vlanUPOverrideValue 0:1 -1
vlanLegacy 0:1 0
vlanDSCP2UPtable 0:1  dscp to up table:
00:00  01:01  02:01  03:01  04:01  05:01  06:01  07:01
08:01  09:01  10:00  11:01  12:00  13:01  14:00  15:01
16:02  17:01  18:03  19:01  20:03  21:01  22:03  23:01
24:03  25:01  26:04  27:01  28:04  29:01  30:04  31:01
32:04  33:01  34:05  35:01  36:05  37:01  38:05  39:01
40:05  41:01  42:01  43:01  44:01  45:01  46:06  47:01
48:06  49:01  50:01  51:01  52:01  53:01  54:01  55:01
56:07  57:01  58:01  59:01  60:01  61:01  62:01  63:01
vapPropIe 0:1  disable (0)
vapWdsService 0:1 none (0)
vapWdsBridge 0:1 disable (0)
vapWdsParentAP 0:1 ""
vapWdsBackParentAP 0:1 ""
vapWdsName 0:1 "14162417085A0000"
vapAirfairEnable 0:1 disable
vapPowerSaveEnable 0:1 disable
vapGroupKpSvRetry 0:1 disable
vapBalanceGroup 0:1 disable
vapMeshType 0:1 static
vapMeshRoamThreshold 0:1 medium
vapMuInitPeriodBehaviour 0:1 defaultPolicy (1)
vapApRedirect 0:1 enable
NumFilterGroup 1
name fnguest_rol # 0 UL 255 DL 255
#  AC in   out  UTCWUTQIO flag     prot     UL  DL  IP              mask     port          tos   p t                         os   p Q rIn rOut
no ucast filter rule
vapStaticEgressVlanList 0:1
vapDynamicEgressVlanList 0:1 24585 0
vapPolicyFlag 0:1 4
vapDefaultAction 0:1 4
vapDefaultContainVlan 0:1 24585
vapCos 0:1 (flag 00 tos 00 mask 00 pri_txq 00 rate 00)
vapRateLimitTbl 0:1 rateIn   0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapRateLimitTbl 0:1 rateOut  0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapTurboVoice 0:1 disable (0)
vapWmmParams 0:1 ac# cwMin cwMax aifs
                 0   4     10    3
                 1   4     10    7
                 2   3     4     2
                 3   2     3     2
# Radio 0 Vns 2
vapSsid 0:2 "fnlan"
vapSessionAvailability 0:2 disable(0)
dot11e 0:2 disable (0)
dot11h 0:2 disable (0)
dot11hPowerBackOff 0:2 disable (0)
qosOverrideBssParam 0:2 0
qosOverrideDscp 0:2 0
vapVidAc 0:2 1
vapMode 0:2 tunnel (0)
vapVlanId 0:2 24584
vapTopoKey2Pvid 0:2 0
vapWmm 0:2 enable (1)
vapCcmpReplayIgnore 0:2 disable (0)
vapSuppressSsid 0:2 disable (0)
vapPrivacy 0:2 WPA2 (6)
vapWepAAA 0:2 disable (0)
vapWpa 0:2 disable (0)
vapWpa2 0:2 enable (1)
vapWepSlotIndex 0:2 0
uapsd 0:2 0
vapKey 0:2
vapPassphraseIndex 0:2 0
vapPassphrase 0:2 ascii "" hex "(null)"
vapGroupKeyInterval 0:2 3600
vapSlowPtkTimeout 0:2 disable (0)
vapOkc 0:2 okc-preauth (3)
vapOkcRetry 0:2 2
vapOkcTimeout 0:2 1
vlanUPOverrideFlag 0:2 0
vlanUPOverrideValue 0:2 -1
vlanLegacy 0:2 0
vlanDSCP2UPtable 0:2  dscp to up table:
vapPropIe 0:2  disable (0)
vapWdsService 0:2 none (0)
vapWdsBridge 0:2 disable (0)
vapWdsParentAP 0:2 ""
vapWdsBackParentAP 0:2 ""
vapWdsName 0:2 "14162417085A0000"
vapAirfairEnable 0:2 disable
vapPowerSaveEnable 0:2 disable
vapGroupKpSvRetry 0:2 disable
vapBalanceGroup 0:2 disable
vapMeshType 0:2 static
vapMeshRoamThreshold 0:2 medium
vapMuInitPeriodBehaviour 0:2 discardNonAuthTraffic (0)
vapApRedirect 0:2 enable
NumFilterGroup 1
name fnlan_rol # 0 UL 255 DL 255
vapStaticEgressVlanList 0:2
vapDynamicEgressVlanList 0:2 24584 0
vapPolicyFlag 0:2 4
vapDefaultAction 0:2 4
vapDefaultContainVlan 0:2 24584
vapCos 0:2 (flag 00 tos 00 mask 00 pri_txq 00 rate 00)
vapRateLimitTbl 0:2 rateIn   0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapRateLimitTbl 0:2 rateOut  0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapTurboVoice 0:2 disable (0)
vapWmmParams 0:2 ac# cwMin cwMax aifs
                 0   4     10    3
                 1   4     10    7
                 2   3     4     2
                 3   2     3     2
# Radio 0 Vns 3
vapSsid 0:3 "corp"
vapSessionAvailability 0:3 disable(0)
dot11e 0:3 disable (0)
dot11h 0:3 disable (0)
dot11hPowerBackOff 0:3 disable (0)
qosOverrideBssParam 0:3 0
qosOverrideDscp 0:3 0
vapVidAc 0:3 3
vapMode 0:3 tunnel (0)
vapVlanId 0:3 -20483
vapTopoKey2Pvid 0:3 0
vapWmm 0:3 enable (1)
vapCcmpReplayIgnore 0:3 disable (0)
vapSuppressSsid 0:3 disable (0)
vapPrivacy 0:3 WPA2-PSK (7)
vapWepAAA 0:3 disable (0)
vapWpa 0:3 disable (0)
vapWpa2 0:3 enable (1)
vapWepSlotIndex 0:3 0
uapsd 0:3 0
vapKey 0:3
vapPassphraseIndex 0:3 3
vapPassphrase 0:3 ascii "corpcorp" hex "(null)"
vapGroupKeyInterval 0:3 3600
vapSlowPtkTimeout 0:3 disable (0)
vapOkc 0:3 preauth-only (2)
vapOkcRetry 0:3 2
vapOkcTimeout 0:3 1
vlanUPOverrideFlag 0:3 0
vlanUPOverrideValue 0:3 -1
vlanLegacy 0:3 0
vlanDSCP2UPtable 0:3  dscp to up table:
vapPropIe 0:3  disable (0)
vapWdsService 0:3 none (0)
vapWdsBridge 0:3 disable (0)
vapWdsParentAP 0:3 ""
vapWdsBackParentAP 0:3 ""
vapWdsName 0:3 "14162417085A0000"
vapAirfairEnable 0:3 disable
vapPowerSaveEnable 0:3 disable
vapGroupKpSvRetry 0:3 disable
vapBalanceGroup 0:3 disable
vapMeshType 0:3 static
vapMeshRoamThreshold 0:3 medium
vapMuInitPeriodBehaviour 0:3 defaultPolicy (1)
vapApRedirect 0:3 enable
NumFilterGroup 1
vapStaticEgressVlanList 0:3
vapDynamicEgressVlanList 0:3 24584 0
vapPolicyFlag 0:3 4
vapDefaultAction 0:3 4
vapDefaultContainVlan 0:3 24584
vapCos 0:3 (flag 00 tos 00 mask 00 pri_txq 00 rate 00)
vapRateLimitTbl 0:3 rateIn   0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapRateLimitTbl 0:3 rateOut  0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapTurboVoice 0:3 disable (0)
vapWmmParams 0:3 ac# cwMin cwMax aifs
                 0   4     10    3
                 1   4     10    7
                 2   3     4     2
                 3   2     3     2
# Radio 0 Vns 4
vapSsid 0:4 ""
vapSessionAvailability 0:4 disable(0)
dot11e 0:4 disable (0)
dot11h 0:4 disable (0)
dot11hPowerBackOff 0:4 disable (0)
qosOverrideBssParam 0:4 0
qosOverrideDscp 0:4 0
vapVidAc 0:4 0
vapMode 0:4 tunnel (0)
vapVlanId 0:4 0
vapTopoKey2Pvid 0:4 0
vapWmm 0:4 enable (1)
vapCcmpReplayIgnore 0:4 disable (0)
vapSuppressSsid 0:4 disable (0)
vapPrivacy 0:4 open (0)
vapWepAAA 0:4 disable (0)
vapWpa 0:4 disable (0)
vapWpa2 0:4 disable (0)
vapWepSlotIndex 0:4 0
uapsd 0:4 1
vapKey 0:4
vapPassphraseIndex 0:4 0
vapPassphrase 0:4 ascii "" hex "(null)"
vapGroupKeyInterval 0:4 1800
vapSlowPtkTimeout 0:4 disable (0)
vapOkc 0:4 preauth-only (2)
vapOkcRetry 0:4 2
vapOkcTimeout 0:4 1
vlanUPOverrideFlag 0:4 0
vlanUPOverrideValue 0:4 -1
vlanLegacy 0:4 1
vlanDSCP2UPtable 0:4  dscp to up table:
vapPropIe 0:4  disable (0)
vapWdsService 0:4 none (0)
vapWdsBridge 0:4 disable (0)
vapWdsParentAP 0:4 "(NONE)"
vapWdsBackParentAP 0:4 "(NONE)"
vapWdsName 0:4 "(NONE)"
vapAirfairEnable 0:4 disable
vapPowerSaveEnable 0:4 disable
vapGroupKpSvRetry 0:4 disable
vapBalanceGroup 0:4 disable
vapMeshType 0:4 static
vapMeshRoamThreshold 0:4 medium
vapMuInitPeriodBehaviour 0:4 discardNonAuthTraffic (0)
vapApRedirect 0:4 disable
NumFilterGroup 0
vapStaticEgressVlanList 0:4
vapDynamicEgressVlanList 0:4
vapPolicyFlag 0:4 0
vapDefaultAction 0:4 0
vapDefaultContainVlan 0:4 0
vapCos 0:4 (flag 40 tos 00 mask 00 pri_txq 00 rate 00) wlanPriDscp
vapRateLimitTbl 0:4 rateIn   0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapRateLimitTbl 0:4 rateOut  0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapTurboVoice 0:4 disable (0)
vapWmmParams 0:4 ac# cwMin cwMax aifs
                 0   4     10    3
                 1   4     10    7
                 2   3     4     2
                 3   2     3     2
# Radio 0 Vns 5
vapSsid 0:5 ""
vapSessionAvailability 0:5 disable(0)
dot11e 0:5 disable (0)
dot11h 0:5 disable (0)
dot11hPowerBackOff 0:5 disable (0)
qosOverrideBssParam 0:5 0
qosOverrideDscp 0:5 0
vapVidAc 0:5 0
vapMode 0:5 tunnel (0)
vapVlanId 0:5 0
vapTopoKey2Pvid 0:5 0
vapWmm 0:5 enable (1)
vapCcmpReplayIgnore 0:5 disable (0)
vapSuppressSsid 0:5 disable (0)
vapPrivacy 0:5 open (0)
vapWepAAA 0:5 disable (0)
vapWpa 0:5 disable (0)
vapWpa2 0:5 disable (0)
vapWepSlotIndex 0:5 0
uapsd 0:5 1
vapKey 0:5
vapPassphraseIndex 0:5 0
vapPassphrase 0:5 ascii "" hex "(null)"
vapGroupKeyInterval 0:5 1800
vapSlowPtkTimeout 0:5 disable (0)
vapOkc 0:5 preauth-only (2)
vapOkcRetry 0:5 2
vapOkcTimeout 0:5 1
vlanUPOverrideFlag 0:5 0
vlanUPOverrideValue 0:5 -1
vlanLegacy 0:5 1
vlanDSCP2UPtable 0:5  dscp to up table:
vapPropIe 0:5  disable (0)
vapWdsService 0:5 none (0)
vapWdsBridge 0:5 disable (0)
vapWdsParentAP 0:5 "(NONE)"
vapWdsBackParentAP 0:5 "(NONE)"
vapWdsName 0:5 "(NONE)"
vapAirfairEnable 0:5 disable
vapPowerSaveEnable 0:5 disable
vapGroupKpSvRetry 0:5 disable
vapBalanceGroup 0:5 disable
vapMeshType 0:5 static
vapMeshRoamThreshold 0:5 medium
vapMuInitPeriodBehaviour 0:5 discardNonAuthTraffic (0)
vapApRedirect 0:5 disable
NumFilterGroup 0
vapStaticEgressVlanList 0:5
vapDynamicEgressVlanList 0:5
vapPolicyFlag 0:5 0
vapDefaultAction 0:5 0
vapDefaultContainVlan 0:5 0
vapCos 0:5 (flag 40 tos 00 mask 00 pri_txq 00 rate 00) wlanPriDscp
vapRateLimitTbl 0:5 rateIn   0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapRateLimitTbl 0:5 rateOut  0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapTurboVoice 0:5 disable (0)
vapWmmParams 0:5 ac# cwMin cwMax aifs
                 0   4     10    3
                 1   4     10    7
                 2   3     4     2
                 3   2     3     2
# Radio 0 Vns 6
vapSsid 0:6 ""
vapSessionAvailability 0:6 disable(0)
dot11e 0:6 disable (0)
dot11h 0:6 disable (0)
dot11hPowerBackOff 0:6 disable (0)
qosOverrideBssParam 0:6 0
qosOverrideDscp 0:6 0
vapVidAc 0:6 0
vapMode 0:6 tunnel (0)
vapVlanId 0:6 0
vapTopoKey2Pvid 0:6 0
vapWmm 0:6 enable (1)
vapCcmpReplayIgnore 0:6 disable (0)
vapSuppressSsid 0:6 disable (0)
vapPrivacy 0:6 open (0)
vapWepAAA 0:6 disable (0)
vapWpa 0:6 disable (0)
vapWpa2 0:6 disable (0)
vapWepSlotIndex 0:6 0
uapsd 0:6 1
vapKey 0:6
vapPassphraseIndex 0:6 0
vapPassphrase 0:6 ascii "" hex "(null)"
vapGroupKeyInterval 0:6 1800
vapSlowPtkTimeout 0:6 disable (0)
vapOkc 0:6 preauth-only (2)
vapOkcRetry 0:6 2
vapOkcTimeout 0:6 1
vlanUPOverrideFlag 0:6 0
vlanUPOverrideValue 0:6 -1
vlanLegacy 0:6 1
vlanDSCP2UPtable 0:6  dscp to up table:
vapPropIe 0:6  disable (0)
vapWdsService 0:6 none (0)
vapWdsBridge 0:6 disable (0)
vapWdsParentAP 0:6 "(NONE)"
vapWdsBackParentAP 0:6 "(NONE)"
vapWdsName 0:6 "(NONE)"
vapAirfairEnable 0:6 disable
vapPowerSaveEnable 0:6 disable
vapGroupKpSvRetry 0:6 disable
vapBalanceGroup 0:6 disable
vapMeshType 0:6 static
vapMeshRoamThreshold 0:6 medium
vapMuInitPeriodBehaviour 0:6 discardNonAuthTraffic (0)
vapApRedirect 0:6 disable
NumFilterGroup 0
vapStaticEgressVlanList 0:6
vapDynamicEgressVlanList 0:6
vapPolicyFlag 0:6 0
vapDefaultAction 0:6 0
vapDefaultContainVlan 0:6 0
vapCos 0:6 (flag 40 tos 00 mask 00 pri_txq 00 rate 00) wlanPriDscp
vapRateLimitTbl 0:6 rateIn   0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapRateLimitTbl 0:6 rateOut  0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapTurboVoice 0:6 disable (0)
vapWmmParams 0:6 ac# cwMin cwMax aifs
                 0   4     10    3
                 1   4     10    7
                 2   3     4     2
                 3   2     3     2
# Radio 0 Vns 7
vapSsid 0:7 ""
vapSessionAvailability 0:7 disable(0)
dot11e 0:7 disable (0)
dot11h 0:7 disable (0)
dot11hPowerBackOff 0:7 disable (0)
qosOverrideBssParam 0:7 0
qosOverrideDscp 0:7 0
vapVidAc 0:7 0
vapMode 0:7 tunnel (0)
vapVlanId 0:7 0
vapTopoKey2Pvid 0:7 0
vapWmm 0:7 enable (1)
vapCcmpReplayIgnore 0:7 disable (0)
vapSuppressSsid 0:7 disable (0)
vapPrivacy 0:7 open (0)
vapWepAAA 0:7 disable (0)
vapWpa 0:7 disable (0)
vapWpa2 0:7 disable (0)
vapWepSlotIndex 0:7 0
uapsd 0:7 1
vapKey 0:7
vapPassphraseIndex 0:7 0
vapPassphrase 0:7 ascii "" hex "(null)"
vapGroupKeyInterval 0:7 1800
vapSlowPtkTimeout 0:7 disable (0)
vapOkc 0:7 preauth-only (2)
vapOkcRetry 0:7 2
vapOkcTimeout 0:7 1
vlanUPOverrideFlag 0:7 0
vlanUPOverrideValue 0:7 -1
vlanLegacy 0:7 1
vlanDSCP2UPtable 0:7  dscp to up table:
vapPropIe 0:7  disable (0)
vapWdsService 0:7 none (0)
vapWdsBridge 0:7 disable (0)
vapWdsParentAP 0:7 "(NONE)"
vapWdsBackParentAP 0:7 "(NONE)"
vapWdsName 0:7 "(NONE)"
vapAirfairEnable 0:7 disable
vapPowerSaveEnable 0:7 disable
vapGroupKpSvRetry 0:7 disable
vapBalanceGroup 0:7 disable
vapMeshType 0:7 static
vapMeshRoamThreshold 0:7 medium
vapMuInitPeriodBehaviour 0:7 discardNonAuthTraffic (0)
vapApRedirect 0:7 disable
NumFilterGroup 0
vapStaticEgressVlanList 0:7
vapDynamicEgressVlanList 0:7
vapPolicyFlag 0:7 0
vapDefaultAction 0:7 0
vapDefaultContainVlan 0:7 0
vapCos 0:7 (flag 40 tos 00 mask 00 pri_txq 00 rate 00) wlanPriDscp
vapRateLimitTbl 0:7 rateIn   0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapRateLimitTbl 0:7 rateOut  0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapTurboVoice 0:7 disable (0)
vapWmmParams 0:7 ac# cwMin cwMax aifs
                 0   4     10    3
                 1   4     10    7
                 2   3     4     2
                 3   2     3     2
# Radio 0 Vns 8
vapSsid 0:8 ""
vapSessionAvailability 0:8 disable(0)
dot11e 0:8 disable (0)
dot11h 0:8 disable (0)
dot11hPowerBackOff 0:8 disable (0)
qosOverrideBssParam 0:8 0
qosOverrideDscp 0:8 0
vapVidAc 0:8 0
vapMode 0:8 tunnel (0)
vapVlanId 0:8 0
vapTopoKey2Pvid 0:8 0
vapWmm 0:8 enable (1)
vapCcmpReplayIgnore 0:8 disable (0)
vapSuppressSsid 0:8 disable (0)
vapPrivacy 0:8 open (0)
vapWepAAA 0:8 disable (0)
vapWpa 0:8 disable (0)
vapWpa2 0:8 disable (0)
vapWepSlotIndex 0:8 0
uapsd 0:8 1
vapKey 0:8
vapPassphraseIndex 0:8 0
vapPassphrase 0:8 ascii "" hex "(null)"
vapGroupKeyInterval 0:8 1800
vapSlowPtkTimeout 0:8 disable (0)
vapOkc 0:8 preauth-only (2)
vapOkcRetry 0:8 2
vapOkcTimeout 0:8 1
vlanUPOverrideFlag 0:8 0
vlanUPOverrideValue 0:8 -1
vlanLegacy 0:8 1
vlanDSCP2UPtable 0:8  dscp to up table:
vapPropIe 0:8  disable (0)
vapWdsService 0:8 none (0)
vapWdsBridge 0:8 disable (0)
vapWdsParentAP 0:8 "(NONE)"
vapWdsBackParentAP 0:8 "(NONE)"
vapWdsName 0:8 "(NONE)"
vapAirfairEnable 0:8 disable
vapPowerSaveEnable 0:8 disable
vapGroupKpSvRetry 0:8 disable
vapBalanceGroup 0:8 disable
vapMeshType 0:8 static
vapMeshRoamThreshold 0:8 medium
vapMuInitPeriodBehaviour 0:8 discardNonAuthTraffic (0)
vapApRedirect 0:8 disable
NumFilterGroup 0
vapStaticEgressVlanList 0:8
vapDynamicEgressVlanList 0:8
vapPolicyFlag 0:8 0
vapDefaultAction 0:8 0
vapDefaultContainVlan 0:8 0
vapCos 0:8 (flag 40 tos 00 mask 00 pri_txq 00 rate 00) wlanPriDscp
vapRateLimitTbl 0:8 rateIn   0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapRateLimitTbl 0:8 rateOut  0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapTurboVoice 0:8 disable (0)
vapWmmParams 0:8 ac# cwMin cwMax aifs
                 0   4     10    3
                 1   4     10    7
                 2   3     4     2
                 3   2     3     2
# Radio 1 Vns 1
vapSsid 1:1 "fnguest"
vapSessionAvailability 1:1 disable(0)
dot11e 1:1 disable (0)
dot11h 1:1 disable (0)
dot11hPowerBackOff 1:1 disable (0)
qosOverrideBssParam 1:1 0
qosOverrideDscp 1:1 0
vapVidAc 1:1 2
vapMode 1:1 tunnel (0)
vapVlanId 1:1 24585
vapTopoKey2Pvid 1:1 0
vapWmm 1:1 enable (1)
vapCcmpReplayIgnore 1:1 disable (0)
vapSuppressSsid 1:1 disable (0)
vapPrivacy 1:1 WPA2-PSK (7)
vapWepAAA 1:1 disable (0)
vapWpa 1:1 disable (0)
vapWpa2 1:1 enable (1)
vapWepSlotIndex 1:1 0
uapsd 1:1 0
vapKey 1:1
vapPassphraseIndex 1:1 1
vapPassphrase 1:1 ascii "argeNtina2014" hex "(null)"
vapGroupKeyInterval 1:1 3600
vapSlowPtkTimeout 1:1 disable (0)
vapOkc 1:1 preauth-only (2)
vapOkcRetry 1:1 2
vapOkcTimeout 1:1 1
vlanUPOverrideFlag 1:1 0
vlanUPOverrideValue 1:1 -1
vlanLegacy 1:1 0
vlanDSCP2UPtable 1:1  dscp to up table:
vapPropIe 1:1  disable (0)
vapWdsService 1:1 none (0)
vapWdsBridge 1:1 disable (0)
vapWdsParentAP 1:1 ""
vapWdsBackParentAP 1:1 ""
vapWdsName 1:1 "14162417085A0000"
vapAirfairEnable 1:1 disable
vapPowerSaveEnable 1:1 disable
vapGroupKpSvRetry 1:1 disable
vapBalanceGroup 1:1 disable
vapMeshType 1:1 static
vapMeshRoamThreshold 1:1 medium
vapMuInitPeriodBehaviour 1:1 defaultPolicy (1)
vapApRedirect 1:1 enable
NumFilterGroup 1
vapStaticEgressVlanList 1:1
vapDynamicEgressVlanList 1:1 24585 0
vapPolicyFlag 1:1 4
vapDefaultAction 1:1 4
vapDefaultContainVlan 1:1 24585
vapCos 1:1 (flag 00 tos 00 mask 00 pri_txq 00 rate 00)
vapRateLimitTbl 1:1 rateIn   0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapRateLimitTbl 1:1 rateOut  0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapTurboVoice 1:1 disable (0)
vapWmmParams 1:1 ac# cwMin cwMax aifs
                 0   4     10    3
                 1   4     10    7
                 2   3     4     2
                 3   2     3     2
# Radio 1 Vns 2
vapSsid 1:2 "fnlan"
vapSessionAvailability 1:2 disable(0)
dot11e 1:2 disable (0)
dot11h 1:2 disable (0)
dot11hPowerBackOff 1:2 disable (0)
qosOverrideBssParam 1:2 0
qosOverrideDscp 1:2 0
vapVidAc 1:2 1
vapMode 1:2 tunnel (0)
vapVlanId 1:2 24584
vapTopoKey2Pvid 1:2 0
vapWmm 1:2 enable (1)
vapCcmpReplayIgnore 1:2 disable (0)
vapSuppressSsid 1:2 disable (0)
vapPrivacy 1:2 WPA2 (6)
vapWepAAA 1:2 disable (0)
vapWpa 1:2 disable (0)
vapWpa2 1:2 enable (1)
vapWepSlotIndex 1:2 0
uapsd 1:2 0
vapKey 1:2
vapPassphraseIndex 1:2 0
vapPassphrase 1:2 ascii "" hex "(null)"
vapGroupKeyInterval 1:2 3600
vapSlowPtkTimeout 1:2 disable (0)
vapOkc 1:2 okc-preauth (3)
vapOkcRetry 1:2 2
vapOkcTimeout 1:2 1
vlanUPOverrideFlag 1:2 0
vlanUPOverrideValue 1:2 -1
vlanLegacy 1:2 0
vlanDSCP2UPtable 1:2  dscp to up table:
vapPropIe 1:2  disable (0)
vapWdsService 1:2 none (0)
vapWdsBridge 1:2 disable (0)
vapWdsParentAP 1:2 ""
vapWdsBackParentAP 1:2 ""
vapWdsName 1:2 "14162417085A0000"
vapAirfairEnable 1:2 disable
vapPowerSaveEnable 1:2 disable
vapGroupKpSvRetry 1:2 disable
vapBalanceGroup 1:2 disable
vapMeshType 1:2 static
vapMeshRoamThreshold 1:2 medium
vapMuInitPeriodBehaviour 1:2 discardNonAuthTraffic (0)
vapApRedirect 1:2 enable
NumFilterGroup 1
vapStaticEgressVlanList 1:2
vapDynamicEgressVlanList 1:2 24584 0
vapPolicyFlag 1:2 4
vapDefaultAction 1:2 4
vapDefaultContainVlan 1:2 24584
vapCos 1:2 (flag 00 tos 00 mask 00 pri_txq 00 rate 00)
vapRateLimitTbl 1:2 rateIn   0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapRateLimitTbl 1:2 rateOut  0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapTurboVoice 1:2 disable (0)
vapWmmParams 1:2 ac# cwMin cwMax aifs
                 0   4     10    3
                 1   4     10    7
                 2   3     4     2
                 3   2     3     2
# Radio 1 Vns 3
vapSsid 1:3 ""
vapSessionAvailability 1:3 disable(0)
dot11e 1:3 disable (0)
dot11h 1:3 disable (0)
dot11hPowerBackOff 1:3 disable (0)
qosOverrideBssParam 1:3 0
qosOverrideDscp 1:3 0
vapVidAc 1:3 0
vapMode 1:3 tunnel (0)
vapVlanId 1:3 0
vapTopoKey2Pvid 1:3 0
vapWmm 1:3 enable (1)
vapCcmpReplayIgnore 1:3 disable (0)
vapSuppressSsid 1:3 disable (0)
vapPrivacy 1:3 open (0)
vapWepAAA 1:3 disable (0)
vapWpa 1:3 disable (0)
vapWpa2 1:3 disable (0)
vapWepSlotIndex 1:3 0
uapsd 1:3 1
vapKey 1:3
vapPassphraseIndex 1:3 0
vapPassphrase 1:3 ascii "" hex "(null)"
vapGroupKeyInterval 1:3 1800
vapSlowPtkTimeout 1:3 disable (0)
vapOkc 1:3 preauth-only (2)
vapOkcRetry 1:3 2
vapOkcTimeout 1:3 1
vlanUPOverrideFlag 1:3 0
vlanUPOverrideValue 1:3 -1
vlanLegacy 1:3 1
vlanDSCP2UPtable 1:3  dscp to up table:
vapPropIe 1:3  disable (0)
vapWdsService 1:3 none (0)
vapWdsBridge 1:3 disable (0)
vapWdsParentAP 1:3 "(NONE)"
vapWdsBackParentAP 1:3 "(NONE)"
vapWdsName 1:3 "(NONE)"
vapAirfairEnable 1:3 disable
vapPowerSaveEnable 1:3 disable
vapGroupKpSvRetry 1:3 disable
vapBalanceGroup 1:3 disable
vapMeshType 1:3 static
vapMeshRoamThreshold 1:3 medium
vapMuInitPeriodBehaviour 1:3 discardNonAuthTraffic (0)
vapApRedirect 1:3 disable
NumFilterGroup 0
vapStaticEgressVlanList 1:3
vapDynamicEgressVlanList 1:3
vapPolicyFlag 1:3 0
vapDefaultAction 1:3 0
vapDefaultContainVlan 1:3 0
vapCos 1:3 (flag 40 tos 00 mask 00 pri_txq 00 rate 00) wlanPriDscp
vapRateLimitTbl 1:3 rateIn   0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapRateLimitTbl 1:3 rateOut  0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapTurboVoice 1:3 disable (0)
vapWmmParams 1:3 ac# cwMin cwMax aifs
                 0   4     10    3
                 1   4     10    7
                 2   3     4     2
                 3   2     3     2
# Radio 1 Vns 4
vapSsid 1:4 ""
vapSessionAvailability 1:4 disable(0)
dot11e 1:4 disable (0)
dot11h 1:4 disable (0)
dot11hPowerBackOff 1:4 disable (0)
qosOverrideBssParam 1:4 0
qosOverrideDscp 1:4 0
vapVidAc 1:4 0
vapMode 1:4 tunnel (0)
vapVlanId 1:4 0
vapTopoKey2Pvid 1:4 0
vapWmm 1:4 enable (1)
vapCcmpReplayIgnore 1:4 disable (0)
vapSuppressSsid 1:4 disable (0)
vapPrivacy 1:4 open (0)
vapWepAAA 1:4 disable (0)
vapWpa 1:4 disable (0)
vapWpa2 1:4 disable (0)
vapWepSlotIndex 1:4 0
uapsd 1:4 1
vapKey 1:4
vapPassphraseIndex 1:4 0
vapPassphrase 1:4 ascii "" hex "(null)"
vapGroupKeyInterval 1:4 1800
vapSlowPtkTimeout 1:4 disable (0)
vapOkc 1:4 preauth-only (2)
vapOkcRetry 1:4 2
vapOkcTimeout 1:4 1
vlanUPOverrideFlag 1:4 0
vlanUPOverrideValue 1:4 -1
vlanLegacy 1:4 1
vlanDSCP2UPtable 1:4  dscp to up table:
vapPropIe 1:4  disable (0)
vapWdsService 1:4 none (0)
vapWdsBridge 1:4 disable (0)
vapWdsParentAP 1:4 "(NONE)"
vapWdsBackParentAP 1:4 "(NONE)"
vapWdsName 1:4 "(NONE)"
vapAirfairEnable 1:4 disable
vapPowerSaveEnable 1:4 disable
vapGroupKpSvRetry 1:4 disable
vapBalanceGroup 1:4 disable
vapMeshType 1:4 static
vapMeshRoamThreshold 1:4 medium
vapMuInitPeriodBehaviour 1:4 discardNonAuthTraffic (0)
vapApRedirect 1:4 disable
NumFilterGroup 0
vapStaticEgressVlanList 1:4
vapDynamicEgressVlanList 1:4
vapPolicyFlag 1:4 0
vapDefaultAction 1:4 0
vapDefaultContainVlan 1:4 0
vapCos 1:4 (flag 40 tos 00 mask 00 pri_txq 00 rate 00) wlanPriDscp
vapRateLimitTbl 1:4 rateIn   0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapRateLimitTbl 1:4 rateOut  0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapTurboVoice 1:4 disable (0)
vapWmmParams 1:4 ac# cwMin cwMax aifs
                 0   4     10    3
                 1   4     10    7
                 2   3     4     2
                 3   2     3     2
# Radio 1 Vns 5
vapSsid 1:5 ""
vapSessionAvailability 1:5 disable(0)
dot11e 1:5 disable (0)
dot11h 1:5 disable (0)
dot11hPowerBackOff 1:5 disable (0)
qosOverrideBssParam 1:5 0
qosOverrideDscp 1:5 0
vapVidAc 1:5 0
vapMode 1:5 tunnel (0)
vapVlanId 1:5 0
vapTopoKey2Pvid 1:5 0
vapWmm 1:5 enable (1)
vapCcmpReplayIgnore 1:5 disable (0)
vapSuppressSsid 1:5 disable (0)
vapPrivacy 1:5 open (0)
vapWepAAA 1:5 disable (0)
vapWpa 1:5 disable (0)
vapWpa2 1:5 disable (0)
vapWepSlotIndex 1:5 0
uapsd 1:5 1
vapKey 1:5
vapPassphraseIndex 1:5 0
vapPassphrase 1:5 ascii "" hex "(null)"
vapGroupKeyInterval 1:5 1800
vapSlowPtkTimeout 1:5 disable (0)
vapOkc 1:5 preauth-only (2)
vapOkcRetry 1:5 2
vapOkcTimeout 1:5 1
vlanUPOverrideFlag 1:5 0
vlanUPOverrideValue 1:5 -1
vlanLegacy 1:5 1
vlanDSCP2UPtable 1:5  dscp to up table:
vapPropIe 1:5  disable (0)
vapWdsService 1:5 none (0)
vapWdsBridge 1:5 disable (0)
vapWdsParentAP 1:5 "(NONE)"
vapWdsBackParentAP 1:5 "(NONE)"
vapWdsName 1:5 "(NONE)"
vapAirfairEnable 1:5 disable
vapPowerSaveEnable 1:5 disable
vapGroupKpSvRetry 1:5 disable
vapBalanceGroup 1:5 disable
vapMeshType 1:5 static
vapMeshRoamThreshold 1:5 medium
vapMuInitPeriodBehaviour 1:5 discardNonAuthTraffic (0)
vapApRedirect 1:5 disable
NumFilterGroup 0
vapStaticEgressVlanList 1:5
vapDynamicEgressVlanList 1:5
vapPolicyFlag 1:5 0
vapDefaultAction 1:5 0
vapDefaultContainVlan 1:5 0
vapCos 1:5 (flag 40 tos 00 mask 00 pri_txq 00 rate 00) wlanPriDscp
vapRateLimitTbl 1:5 rateIn   0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapRateLimitTbl 1:5 rateOut  0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapTurboVoice 1:5 disable (0)
vapWmmParams 1:5 ac# cwMin cwMax aifs
                 0   4     10    3
                 1   4     10    7
                 2   3     4     2
                 3   2     3     2
# Radio 1 Vns 6
vapSsid 1:6 ""
vapSessionAvailability 1:6 disable(0)
dot11e 1:6 disable (0)
dot11h 1:6 disable (0)
dot11hPowerBackOff 1:6 disable (0)
qosOverrideBssParam 1:6 0
qosOverrideDscp 1:6 0
vapVidAc 1:6 0
vapMode 1:6 tunnel (0)
vapVlanId 1:6 0
vapTopoKey2Pvid 1:6 0
vapWmm 1:6 enable (1)
vapCcmpReplayIgnore 1:6 disable (0)
vapSuppressSsid 1:6 disable (0)
vapPrivacy 1:6 open (0)
vapWepAAA 1:6 disable (0)
vapWpa 1:6 disable (0)
vapWpa2 1:6 disable (0)
vapWepSlotIndex 1:6 0
uapsd 1:6 1
vapKey 1:6
vapPassphraseIndex 1:6 0
vapPassphrase 1:6 ascii "" hex "(null)"
vapGroupKeyInterval 1:6 1800
vapSlowPtkTimeout 1:6 disable (0)
vapOkc 1:6 preauth-only (2)
vapOkcRetry 1:6 2
vapOkcTimeout 1:6 1
vlanUPOverrideFlag 1:6 0
vlanUPOverrideValue 1:6 -1
vlanLegacy 1:6 1
vlanDSCP2UPtable 1:6  dscp to up table:
vapPropIe 1:6  disable (0)
vapWdsService 1:6 none (0)
vapWdsBridge 1:6 disable (0)
vapWdsParentAP 1:6 "(NONE)"
vapWdsBackParentAP 1:6 "(NONE)"
vapWdsName 1:6 "(NONE)"
vapAirfairEnable 1:6 disable
vapPowerSaveEnable 1:6 disable
vapGroupKpSvRetry 1:6 disable
vapBalanceGroup 1:6 disable
vapMeshType 1:6 static
vapMeshRoamThreshold 1:6 medium
vapMuInitPeriodBehaviour 1:6 discardNonAuthTraffic (0)
vapApRedirect 1:6 disable
NumFilterGroup 0
vapStaticEgressVlanList 1:6
vapDynamicEgressVlanList 1:6
vapPolicyFlag 1:6 0
vapDefaultAction 1:6 0
vapDefaultContainVlan 1:6 0
vapCos 1:6 (flag 40 tos 00 mask 00 pri_txq 00 rate 00) wlanPriDscp
vapRateLimitTbl 1:6 rateIn   0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapRateLimitTbl 1:6 rateOut  0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapTurboVoice 1:6 disable (0)
vapWmmParams 1:6 ac# cwMin cwMax aifs
                 0   4     10    3
                 1   4     10    7
                 2   3     4     2
                 3   2     3     2
# Radio 1 Vns 7
vapSsid 1:7 ""
vapSessionAvailability 1:7 disable(0)
dot11e 1:7 disable (0)
dot11h 1:7 disable (0)
dot11hPowerBackOff 1:7 disable (0)
qosOverrideBssParam 1:7 0
qosOverrideDscp 1:7 0
vapVidAc 1:7 0
vapMode 1:7 tunnel (0)
vapVlanId 1:7 0
vapTopoKey2Pvid 1:7 0
vapWmm 1:7 enable (1)
vapCcmpReplayIgnore 1:7 disable (0)
vapSuppressSsid 1:7 disable (0)
vapPrivacy 1:7 open (0)
vapWepAAA 1:7 disable (0)
vapWpa 1:7 disable (0)
vapWpa2 1:7 disable (0)
vapWepSlotIndex 1:7 0
uapsd 1:7 1
vapKey 1:7
vapPassphraseIndex 1:7 0
vapPassphrase 1:7 ascii "" hex "(null)"
vapGroupKeyInterval 1:7 1800
vapSlowPtkTimeout 1:7 disable (0)
vapOkc 1:7 preauth-only (2)
vapOkcRetry 1:7 2
vapOkcTimeout 1:7 1
vlanUPOverrideFlag 1:7 0
vlanUPOverrideValue 1:7 -1
vlanLegacy 1:7 1
vlanDSCP2UPtable 1:7  dscp to up table:
vapPropIe 1:7  disable (0)
vapWdsService 1:7 none (0)
vapWdsBridge 1:7 disable (0)
vapWdsParentAP 1:7 "(NONE)"
vapWdsBackParentAP 1:7 "(NONE)"
vapWdsName 1:7 "(NONE)"
vapAirfairEnable 1:7 disable
vapPowerSaveEnable 1:7 disable
vapGroupKpSvRetry 1:7 disable
vapBalanceGroup 1:7 disable
vapMeshType 1:7 static
vapMeshRoamThreshold 1:7 medium
vapMuInitPeriodBehaviour 1:7 discardNonAuthTraffic (0)
vapApRedirect 1:7 disable
NumFilterGroup 0
vapStaticEgressVlanList 1:7
vapDynamicEgressVlanList 1:7
vapPolicyFlag 1:7 0
vapDefaultAction 1:7 0
vapDefaultContainVlan 1:7 0
vapCos 1:7 (flag 40 tos 00 mask 00 pri_txq 00 rate 00) wlanPriDscp
vapRateLimitTbl 1:7 rateIn   0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapRateLimitTbl 1:7 rateOut  0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapTurboVoice 1:7 disable (0)
vapWmmParams 1:7 ac# cwMin cwMax aifs
                 0   4     10    3
                 1   4     10    7
                 2   3     4     2
                 3   2     3     2
# Radio 1 Vns 8
vapSsid 1:8 ""
vapSessionAvailability 1:8 disable(0)
dot11e 1:8 disable (0)
dot11h 1:8 disable (0)
dot11hPowerBackOff 1:8 disable (0)
qosOverrideBssParam 1:8 0
qosOverrideDscp 1:8 0
vapVidAc 1:8 0
vapMode 1:8 tunnel (0)
vapVlanId 1:8 0
vapTopoKey2Pvid 1:8 0
vapWmm 1:8 enable (1)
vapCcmpReplayIgnore 1:8 disable (0)
vapSuppressSsid 1:8 disable (0)
vapPrivacy 1:8 open (0)
vapWepAAA 1:8 disable (0)
vapWpa 1:8 disable (0)
vapWpa2 1:8 disable (0)
vapWepSlotIndex 1:8 0
uapsd 1:8 1
vapKey 1:8
vapPassphraseIndex 1:8 0
vapPassphrase 1:8 ascii "" hex "(null)"
vapGroupKeyInterval 1:8 1800
vapSlowPtkTimeout 1:8 disable (0)
vapOkc 1:8 preauth-only (2)
vapOkcRetry 1:8 2
vapOkcTimeout 1:8 1
vlanUPOverrideFlag 1:8 0
vlanUPOverrideValue 1:8 -1
vlanLegacy 1:8 1
vlanDSCP2UPtable 1:8  dscp to up table:
vapPropIe 1:8  disable (0)
vapWdsService 1:8 none (0)
vapWdsBridge 1:8 disable (0)
vapWdsParentAP 1:8 "(NONE)"
vapWdsBackParentAP 1:8 "(NONE)"
vapWdsName 1:8 "(NONE)"
vapAirfairEnable 1:8 disable
vapPowerSaveEnable 1:8 disable
vapGroupKpSvRetry 1:8 disable
vapBalanceGroup 1:8 disable
vapMeshType 1:8 static
vapMeshRoamThreshold 1:8 medium
vapMuInitPeriodBehaviour 1:8 discardNonAuthTraffic (0)
vapApRedirect 1:8 disable
NumFilterGroup 0
vapStaticEgressVlanList 1:8
vapDynamicEgressVlanList 1:8
vapPolicyFlag 1:8 0
vapDefaultAction 1:8 0
vapDefaultContainVlan 1:8 0
vapCos 1:8 (flag 40 tos 00 mask 00 pri_txq 00 rate 00) wlanPriDscp
vapRateLimitTbl 1:8 rateIn   0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapRateLimitTbl 1:8 rateOut  0=0 1=0 2=0 3=0 4=0 5=0 6=0 7=0 8=0
vapTurboVoice 1:8 disable (0)
vapWmmParams 1:8 ac# cwMin cwMax aifs
                 0   4     10    3
                 1   4     10    7
                 2   3     4     2
                 3   2     3     2
Photo of Pascal Lurquin
Pascal Lurquin
  • 970 Points 500 badge 2x thumb
Same problem for me with 3825i : Have you found the solution ?
