AP wing 7522 adapt to rfs 7000 controller
Resolut1on
Contributor
I have AP wing 7522 and I don't know how to adapt it to rfs 7000 controller.
Please help me. Thank you
5 REPLIES 5
Andrew_Webster
New Contributor III
You may also want to verify that your RFS 7000 controller is running at minimum a version of firmware that supports the AP 7522.
Yes exactly.
Timo1
New Contributor II
For a basic setup very easy. Connect all APs and RFS within the same VLAN. That's it.
You can extend this with Adoption Policy to create intelligent Zero Touch Deployment.
Timo1
New Contributor II
WiNG have so much options you can do.
You can find some "How To" under WiNG Software:
http://www.extremenetworks.com/support/documentation/
