AP3805i, AP3825i and AP3610i Radiation patterns.
  • Question
  • Updated 3 years ago
  • Answered
I know there is "External Antenna Site Preparation and Installation" document on extranet which covers all external antenna radiation patterns and installation notes. But I can't seem to find any document about internal antenna models.
So does these models radiate like spheres or like donut shape like external omni antennas? What is the best method to install them? Ceilings or brick wall mount? most of our 3610 and 3825 models are mounted to walls becouse it was easy to mount but I wonder if we could get better coverage if we mount them to ceilings.
Thanks.
Photo of Rahman Duran
Rahman Duran
  • 2,012 Points 2k badge 2x thumb
Posted 3 years ago
Photo of Roaming 24/7
Roaming 24/7
  • 350 Points 250 badge 2x thumb
They radiate with a spherical pattern. Mounting on a wall vertically will only gain you better coverage if you are going for coverage on two floors. We are on the process of installing 200 + APs mostly in an outdoor environment. We have installed about 30% but have only turned up one AP for testing in an office environment. We are working on compliance items before we can go to production. We have high acceptance criteria requirements and density requirements. Looking forward to testing and validation. This is going to be our first experience with Extreme gear.
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,514 Points 20k badge 2x thumb
Take a look at the product datasheets for the access points. The signal pattern is listed.
http://www.extremenetworks.com/product/ap3805
Also reference the following Tech Note about the 3610 wall/ceiling mounting:
https://extremenetworks.box.com/s/pq4zo7tk4i72ywvuur9q3ef1mw6gbp6y
Photo of Laura
Laura
  • 1,490 Points 1k badge 2x thumb
Are there any data sheets available for Enterasys 3605 Access Point Radiation Diagrams? I only saw version 3700 and up.
Photo of Doug Hyde
Yes, I will email that to you...
