AP3805i connect only at 100 Mb at X440G2-48p-10G4 switch
  • 2
  • Problem
  • Updated 4 months ago
  • Solved
I have more than 50 AP 3805i connected at X440G2-24p-10G4 and X440G2-48p-10G4 switches.
One AP connect with 100 mb instead of 1Gb.
Port settting on the switch is auto. Also at the AP.
I noticed that the interface setting on the AP is 10 or 100 Mb and not 1Gb??.
I already cleared the config of the AP but it stays 100 Mb
Other AP’s connect with 1Gb.
Photo of Johan Hendrikx
Johan Hendrikx
  • 3,876 Points 3k badge 2x thumb
Posted 5 months ago
  • 2
Photo of Aman Choubey
Aman Choubey
  • 754 Points 500 badge 2x thumb
Hi johan,
did you reset the AP?
from where you see your AP is showing low link speed?
Aman Choubey
It could be due to cable fault also!!
please check once and do the factory default AP.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 51,164 Points 50k badge 2x thumb
I agree, check the cabling...
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 10,186 Points 10k badge 2x thumb
If you move that AP to different port, will that change? If you swap AP with other AP in the same port. Will that change?
Aman Choubey
i don't think it will work, bcz all remaining APs except this AP are working on gig link.
(Edited)
Johan Hendrikx
I did a reset of the AP.  I see the slow link in the dashboard and on the switch. I will check the cabling.
Aman Choubey
do you have any WLC?
Aman Choubey
one thing you can also try just manually configure the link speed  for that APs.
(Edited)
Johan Hendrikx
The link speed will be 10 Mb of 100 Mb. I cann't select 1Gb
Aman Choubey
on switch you can configure the Speed for that particular port.
"configure port <port#> auto off speed < speed > duplex <half | full>"
like this.
you'll have to check the cable, a lot of times we see problems with the cable category.
Johan Hendrikx
cable is replaced and teh connection is 1GB. Thanks all
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,710 Points 20k badge 2x thumb
