AP3865 installation?
  • Question
  • Updated 3 years ago
  • Answered
Hi all,
have you already installed an AP3865?
What outdoor RJ45 cable vendor/manufacturer have you used?
If you use a standard RJ45 cable with bend protection
the gland adapter of the AP are very tight.
Photo of Peter Ruester
Peter Ruester
  • 170 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Dennis Rysell
Dennis Rysell, Employee
  • 220 Points 100 badge 2x thumb
Is the issue with the plastic LAN connector, or a snug fit of the LAN cable in the soft rubber gasket. If it is the LAN cable fit, what is the diameter of the LAN cable, with bend protection, insulator? Is there a LAN cable part number we can get the dimensions for on the web?
Also note that the tighter the fit of the LAN cable in the gasket the better the water seal should be.
