AP3865e and WS-AO-DS02360N3
  • Question
  • Updated 2 years ago
  • Answered
Dear all,
i have AP3865e and 03 antenna DS02360N3, i want use 06 antenna DS02360N3 then power (dbm) and gain (dbi) of AP3865e is how much?
thanks!
Photo of Pham Thach
Pham Thach
  • 80 Points 75 badge 2x thumb
Posted 2 years ago
Photo of Rajesh Jeevendran
Rajesh Jeevendran, Employee
  • 354 Points 250 badge 2x thumb
Hi Pham
Thank you for raising this post.
AP 3865e platform support only 3×3:3,3 spacial streams at time.
The antennae has 2dbm gain.
Please let me know your requirement for installing 6 antennae.
Proper sight survey has to be made before deciding the power settings.
However I would recommended the minimal 6dbm power initially and further tweek based on the spectrum analysis.
Regards
Rajesh J
Photo of Pham Thach
Pham Thach
Hi Rajesh,
I am currently using a AP3865e with 3 antennas DS02360N3, but I see wave is very weak (I have put AP on the 5 meter high column, column foot only 1 bar wave), can I improve if 3 more antennas are added?
and with 6 antennas this , the total gain is still only 2dbi at 2.4GHz ?
thanks!
(Edited)
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 49,992 Points 20k badge 2x thumb
With that little input my assumption is that the antennas are not installed correctly.
1) Do you use WLAN on the 2.4GHz OR 5GHz band on this AP OR on both frequencies/radios.
2) From the below picture - which antenna connectors do you use right now, please tell us the number
