AP3865e External SSID Problems
  • Problem
  • Updated 1 year ago
  • Solved
I have installed AP3865e External, i can see all the SSID-s on mobile phone and in some llaptops but in some llaptops i cannot see the SSID. I have and older Wireless AP3660 External on this AP works fine both mobile and all llaptops. Can anyone help me with this problem.
Here is my settings of my AP radio 1 and radio 2
Radio 1
Radio 1 Advanced Settings
Radio 2
Radio 2 Advanced Settings
Photo of Shkelqim Kajtazi
Shkelqim Kajtazi
  • 384 Points 250 badge 2x thumb
Posted 1 year ago
Photo of Rajesh Jeevendran
Rajesh Jeevendran, Employee
  • 354 Points 250 badge 2x thumb
Hi Shkelqim
Thank you for the post.
Laptops that couldn't see the SSID, could you check if they are configured for G only or A only mode.
Is there a difference in wireless NIC driver among the working and non-working laptop.
Regards
Rajesh J
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 9,620 Points 5k badge 2x thumb
I would guess the issue is with the wireless nic or drivers. Check if the behavior is the same if you change channels. Some clients does not support all frequencies (like DFS channels).
I mean configure the 3865 to use the same channel as you have on 3660. And check that.
Shkelqim Kajtazi
This one worked, im just do more tests in diferent laptops thank you so much for your help.
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,588 Points 5k badge 2x thumb
Hi
I would start with more conservative radio settings at first:
2.4 20mhz channel width and use 1,6,11 - channel 13 is not always supported by client.
5Ghz - avoid auto width, start with 20Mhz and work from there if you need more.
Disable AMSDU and LDPC on both radio
-Gareth
Photo of Ostrovsky, Yury
Ostrovsky, Yury, Employee
  • 3,050 Points 3k badge 2x thumb
Looks like your chosen channels can be a problem for some clients - on 5Ghz radio its "108" choosen which is DFS channel , and ch 13 is also not very good . Check  this web link to see if the capability of particular wireless client :
http://clients.mikealbano.com/
