AP3912: 802.1X and MAC-Auth parallel on wired ports ?
  • Question
  • Updated 5 days ago
Hello !
I need 802.1X and MAC-Auth parallel on wired Ports of AP3912i. In the WLAN-Profile > Auth& Acct you can configure 802.1X and MAC-Auth with configuration of the RADIUS Servers for X and MAC. In my configuration 802.1X works perfect with rule overwrite from control ... but I see no MAC auth on clients not supporting 802.1X.
Is that supported ?
Has anybody this configuration up and running ?
Thx for information...
br
Volker
Photo of Volker Kull
Volker Kull
  • 1,882 Points 1k badge 2x thumb
Posted 5 days ago
Photo of John Romero
John Romero
  • 320 Points 250 badge 2x thumb
I am using 3912s in our dorms and I was able to get the Pass through port to work with both 802.1x and MAC auth. This is because the switch port handles the multi-auth. My p1,p2 and p3 ports are tied to a certain SSID which doesn't handle multi auth, from what I've seen.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 51,044 Points 50k badge 2x thumb
So the WLAN service that is used is just open/none ?
I'm also not able to connect my Samsung TV to the 3912 using a WLAN service with privacy WPA = 802.1X + MAC auth.
I use a PSK WLAN service with MAC auth enabled with ExtremeControl in that case = PSK WLAN for other non-802.1X capable wireless clients.
