AP3935 and C25 Wireless Controller Compatibility
Rick_Lester
Are the new Wave2 AP3935 APs compatible with the older C25 controllers? I would assume they are compatible with recent firmware on the controller, but I'm not finding documentation that mentions whether they are or not.
6 REPLIES 6
Rick_Lester
Thanks guys. That's exactly what I needed!
Ronald_Dvorak
Honored Contributor
4 answers within 5 minutes, well done guys 
Ronald_Dvorak
Honored Contributor
Here the link to the release notes main page....
http://www.extremenetworks.com/support/release-notes
-Ron
Craig_Guilmette
Yes they are. The controller release notes is where you find the answer. It will list the particular model AP's as supported AP's. If you don't see the AP listed you need to upgrade higher. If memory serves me correctly the V10 code is when they were added.
