AP3935i send disassociation packet
  • Problem
  • Updated 1 year ago
  • Solved
Good Afternoon, we have AP3935i last firmware 10.31.2.7 that send disassociation packet to a voip client. The VoIP client is not able to connect to another AP for 10 seconds.
Example: We are talking near the AP when the AP send disassociation frame and the client disconnect from network for 10 seconds or 12.
Could be a firmware problem?
Regards
Giuseppe
Photo of Giuseppe Montanarella
  • 520 Points 500 badge 2x thumb
  • frustated
Posted 1 year ago
Photo of Ostrovsky, Yury
Ostrovsky, Yury, Employee
  • 3,050 Points 3k badge 2x thumb
Ideally to have wireless trace , so we can see the Disconnect reason if any (usually coming with the disconnect code #)
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,192 Points 20k badge 2x thumb
Hello Giuseppe,
Sorry that you are frustrated, we will be glad to look into this further. We should look at your AP settings as well as any traces you have for this issue. I would suggest you contact the GTAC so we can review all of your information.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-contact-Extreme-Networks-Global-Tec...
Doug Hyde
Extreme Networks
Good Morning, we opened a ticket and now the ticket is managed by Mitchell Gareth, I hope to find a quik solution :-)
Photo of Doug Hyde
You are in good hands then. :-)
