AP6532 and AP7522
  • Question
  • Updated 1 year ago
  • Answered
Hi!!!!!
I have this 2 models in the same site for now. AP7522 detect but dont manage the AP6532, but AP6532 dont display fine the UI when detect AP7522 in the same network. How to fix this meanwhile replace de old AP!?
Thx
Photo of Rodrigo Cortes
Rodrigo Cortes
  • 490 Points 250 badge 2x thumb
Posted 1 year ago
Photo of Andrew Webster
Andrew Webster
  • 1,816 Points 1k badge 2x thumb
Hi Rodrigo,
It sounds like you do not have a controller.  You cannot manage different AP models together without a controller.
You would need to install RFS4000 or VX9000 or similar to be able to manage these from a single point.
Rodrigo Cortes
Hi Andrew!
I know but why one model detect the other and affect the UI for the old model...
Photo of Robert Zarzycki
Robert Zarzycki, Employee
  • 4,292 Points 4k badge 2x thumb
Rodrigo, what firmware versions are you running on each AP?
Photo of Timo
Timo
  • 3,210 Points 3k badge 2x thumb
What do you mean with detect? See it as MINT neighbor?
Which UI do you use, Express, Swift or WiNG?
Rodrigo Cortes
Hi Robert,
Both have 5.8.5.0-016R
Thx
Photo of Christoph S.
Christoph S., Employee
  • 2,814 Points 2k badge 2x thumb
Hello Rodrigo,
As Robert mentioned above, we will need to know what firmware version each is running on. We would also need to know if you've configured one or both as virtual controllers. It seems like you have the AP7522 set up as a virtual controller, but we'll need your confirmation on this. If this is the case I would recommend you disable this feature and just use both as independent APs.
Regards,
Chris
You can try disabling Mint Link setting Or change the Area Identifier id. This should prevent APs from seeing each other via mint.
(Edited)
Rodrigo Cortes
Hi!!! both are virtual controller for your own models. Have 8 AP7522 and 2 6532.
Where found this two setting!?
Thx
Since they are both VC, change the Area Identifier id. This should keep all  APs only seeing APs from its own VC.
Rodrigo Cortes
Hi!!! i see the picture now!!!! i change the are from default to 2 into Ap6532 and to 1 for Ap7522.
now AP6532 work fine, UI show me the data correctly!
Thx
Hello Rodrigo,
You cannot have 2 virtual controllers in the same broadcast domain. What UI are you using, Swift or Enterprise?
Regards,
Chris
Rodrigo Cortes
Hello Chris...
I use Enterprise, AP6532 in few weeks have to replace...
Thx
