AP7161 Rado Antenna Configuration
Ian_Pedrosa
Do you have to use all of the AP7161's radio antenna connectors? Are the radios configurable for 2x2 or 3x3 in the GUI or CLI or is it just a matter of not using certain antenna connectors on the AP?
6 REPLIES 6
Bin
Hello Lan
There is the screenshot from GUI at Radio Setting tab.
You could set the number of transmit and receive antennas from Antenna Mode.
Best regards,
Bin
Bin
No Tuan
The default setting is dynamic based on the Access Point model deployed and its transmit power settings.
Thanks.
Tuan_Nguyen
New Contributor II
Hi Bin
I used 3x3 antena, Can i set anten mode default?
Christoph_S
The changes can be made from GUI only on APs accessed via the Enterprise UI. They are not available for APs accessed via Swift UI (also called Express UI)
Assuming you are accessing the AP using the Enterprise UI:
Go to Configuration > Devices > Device Overrides > Double click on the AP in the list > Expand Interface > Radios > Double click on the Radio you'd like to hide it on for example Radio 1 > Radio settings > Antenna Mode > select your choice from the drop down menu > Ok > Exit > Commit and Save.
The above is configured as an override; however, it can also be configured as a system profile setting should you have multiple APs adopted onto a controller or a virtual controller.
I hope this helps,
Regards,
Chris
Christoph S.
