AP7522 - 2.4GHz radio Antenna
  • Question
  • Updated 1 year ago
  • Answered
Can the  ML-2499-HPA3-02R antenna be used on the 2.4GHz radio of AP 7522?
Thank you in advance.
Photo of gluo
gluo
  • 600 Points 500 badge 2x thumb
Posted 1 year ago
Photo of Andrew Webster
Andrew Webster
  • 1,746 Points 1k badge 2x thumb
Photo of gluo
gluo
Hi Andrew,
Thank you I've seen that and it says it is not compatible.
Maybe you could answer also this. Do both antenna connectors on the 7522 support both 2.4 and 5 GHz or one is for 2.4Ghz and the other for 5Ghz?
Thank you.
Andrew Webster
The 7522 antenna connectors are dual-band RP-SMA (both radios use it).   That technically wouldn't stop you from using the ML-2499 with the correct adapter, however, the 5GHz radio cannot be used and should be turned off in this scenario.   It may also not be "legal" depending on your jurisdiction.
Photo of Christoph S.
Christoph S., Employee
  • 2,560 Points 2k badge 2x thumb
Hello Nikolou,
Both connectors are dual band so they support both 2.4 and 5 GHz.
Regards,
Chris
Photo of gluo
gluo
Thank all you for your answers.
