AP7522 Wing Express interface ge1 DOWN
Ronald_Groenewe
I've made a change via the GUI and it has disabled the GE1 by default. So now I cannot access the interface anymore. As the wireless networks are in a different VLAN I'm unable to check the settings in the web interface.
Is there a way to enable interface GE1 again via the CLI?
7 REPLIES 7
Christoph_S
Hello Ronald,
It is unclear if this is an AP7522E express unit or a standard AP7522 with the Express (Swift) UI. If it's an Express unit meaning AP7522E, then as previously mentioned, it has to be factory reset via the console port; however, if it's a standard AP7522 unit with Express UI, then you can console into it (baud rate 115200) and run the following commands to open the GE1 port:
>en
#self
Enter configuration commands, one per line. End with CNTL/Z.
#int ge 1
#no shut
#com wr
Regards,
Chris
Christoph S.
it's a 7522E so no self on the console... I'm currently reconfiguring the AP
but I appreciate your input!
Ronald_Groenewe
Hi Ondrej,
This is exactly what happened, I updated the allowed VLANS and it turned the interface OFF.
Should this have been solved in the firmware I'm using?
Hi Ronald,
this is unfortunately SwiftUI module related issue and it is not easy to solve this.
As afar as my knowledge goes, fix is planed in WiNG 5.9 which is due to be released during summer.
Regards,
Ondrej
