AP7532 Mesh GE1 port configuration
Nathan_Derichsw
I have a Mesh network set up with 2 AP7532. One is in the garage and I want to connect a PC to via ethernet. It is possible to configure GE1 port to connect to computer?
I tried enabling the port, but doesnt seem to be helping.
! Configuration of AP7532 version 5.9.2.0-032R
version 2.5
client-identity-group default
load default-fingerprints
ip snmp-access-list default
permit any
firewall-policy default
no ip dos tcp-sequence-past-window
mint-policy global-default
meshpoint-qos-policy default
rate-limit meshpoint to-air
rate-limit meshpoint from-air
rate-limit neighbor to-air
rate-limit neighbor from-air
wlan-qos-policy default
qos trust dscp
qos trust wmm
radio-qos-policy default
wlan wlan1
ssid wlan1
vlan 1
bridging-mode tunnel
encryption-type ccmp
authentication-type none
wpa-wpa2 psk 0 0123456789
meshpoint nateMesh
meshid nateMesh
beacon-format mesh-point
control-vlan 1
allowed-vlans 1
security-mode psk
no root
management-policy default
no telnet
http server
https server
rest-server
no ftp
ssh
user admin password 1 344fb3d332a61eb6e616cee030d0567207d82164eac42b4dad6fd80f99375b6e role superuser access all
snmp-server community 0 private rw
snmp-server community 0 public ro
snmp-server user snmptrap v3 encrypted des auth md5 0 admin123
snmp-server user snmpmanager v3 encrypted des auth md5 0 admin123
profile ap7532 default-ap7532
autoinstall configuration
autoinstall firmware
crypto ikev1 policy ikev1-default
isakmp-proposal default encryption aes-256 group 2 hash sha
crypto ikev2 policy ikev2-default
crypto ipsec transform-set default esp-aes-256 esp-sha-hmac
crypto ikev1 remote-vpn
crypto ikev2 remote-vpn
crypto auto-ipsec-secure
crypto load-management
crypto remote-vpn-client
interface radio1
wlan wlan1 bss 1 primary
interface radio2
interface ge1
interface vlan1
ip address dhcp
ip address zeroconf secondary
ip dhcp client request options all
interface pppoe1
use firewall-policy default
use client-identity-group default
rf-domain-manager capable
logging on
service pm sys-restart
router ospf
adoption-mode controller
rf-domain default
country-code us
ap7532 XXXXXXXXXXXXXXXXXX
use profile default-ap7532
use rf-domain default
hostname ap7532-XXXXX
area Garage
interface radio2
meshpoint nateMesh bss 2
meshpoint-device nateMesh
end
1 REPLY 1
Daren_Ellis
Hi Nathan,
You did not specify which config you are presenting.
Also you did not mention if the Mesh was established or not,
In either case the configuration seems incomplete.
Please make the following setting changes and retest.
On both devices
no ip dos
no ip-mac conflict
no ip-mac routing conflict
no stateful-packet-inspection-l2
Root Device (Mesh point needs to be on BSS 1)
interface radio2
meshpoint nateMesh bss 1
no dynamic-chain-selection
root
preferred interface 5GHz
path-method uniform
Non Root device (Mesh point needs to be on BSS 1)
interface radio2
no root
path-method uniform
Notes:
We would not recommend broadcasting a WLAN and utilizing the Mesh on the same radio as that reduces performance (If you are not planning on having wireless clients on the 5Ghz band please remove the WLAN).
Please also use static channel and power assignments for the radio the mesh is assigned to.
In your case radio 2
