Appears in the log: "Unit Leave:2", and "Unit Join:2" very constantly
  • Question
  • Updated 2 years ago
  • Answered
Hi all,
A have a stack Enterasys B5 with 4 equipments in the IDF. In some cases, some users told me that are out of the network and suddenly are on line again.
I made a review of the switches, and found this in the log:
<162> JAN 10 01:09:08 130.40.36.88-4 EDB[226211192]: edb.c(600) 56 %% EDB Callback: Unit Leave: 2.
<162> JAN 10 01:09:08 130.40.36.88-3 EDB[240444136]: edb.c(600) 57 %% EDB Callback: Unit Leave: 2.
<162>Jan 10 01:09:36 130.40.36.88-1 EDB[240446072]: edb.c(494) 267 %% EDB Callback: Unit Join: 2.
<162> JAN 13 16:22:39 130.40.36.88-3 EDB[240444136]: edb.c(600) 59 %% EDB Callback: Unit Leave: 2.
<162>Jan 13 16:22:46 130.40.36.88-1 EDB[240446072]: edb.c(600) 272 %% EDB Callback: Unit Leave: 2.
<162> JAN 13 16:22:47 130.40.36.88-4 EDB[226211192]: edb.c(600) 58 %% EDB Callback: Unit Leave: 2.
<162>Jan 13 16:23:13 130.40.36.88-1 EDB[240446072]: edb.c(494) 277 %% EDB Callback: Unit Join: 2.
<162>Feb  3 16:46:46 130.40.36.88-1 EDB[240446072]: edb.c(600) 333 %% EDB Callback: Unit Leave: 2.
<162> FEB 03 16:46:51 130.40.36.88-4 EDB[226211192]: edb.c(600) 60 %% EDB Callback: Unit Leave: 2.
<162> FEB 03 16:46:51 130.40.36.88-3 EDB[240444136]: edb.c(600) 61 %% EDB Callback: Unit Leave: 2.
<162>Feb  3 16:47:18 130.40.36.88-1 EDB[240446072]: edb.c(494) 341 %% EDB Callback: Unit Join: 2.
<162> FEB 03 19:17:41 130.40.36.88-4 EDB[226211192]: edb.c(600) 62 %% EDB Callback: Unit Leave: 2.
<162> FEB 03 19:17:41 130.40.36.88-3 EDB[240444136]: edb.c(600) 63 %% EDB Callback: Unit Leave: 2.
<162>Feb  3 19:17:46 130.40.36.88-1 EDB[240446072]: edb.c(600) 362 %% EDB Callback: Unit Leave: 2.
<162>Feb  3 19:18:13 130.40.36.88-1 EDB[240446072]: edb.c(494) 366 %% EDB Callback: Unit Join: 2.
So, my question is:
- is there a problem with the switch? I mean: IOS, firmware, cable o the appliance? do I have to upgrade the firmware? the info about this is this:
Chassis Serial Number:      xxxxxxxx
Chassis Firmware Revision:  06.71.02.0008
IDF_P4(rw)->
        UNIT 2 HARDWARE INFORMATION
        Model:                          B5G124-48P2
        Serial Number:                  xxxxxxxxx
        Vendor ID:                      0xbc00
        Base MAC Address:               xxxxxxxxx
        Hardware Version:               BCM56514 REV 1
        POE Board Version:              0.0
        FirmWare Version:               06.71.02.0008
        Boot Code Version:              02.02.51
        POE Version:                    2_1
I hope this info be usefull to help me to find the solution.
Thank you!!
P.D. Sorry for my bad english.
Photo of Manuel_Pineda
Manuel_Pineda
  • 100 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Jason Parker
Jason Parker, Employee
  • 2,908 Points 2k badge 2x thumb
Good Day to you Manuel,
It could be a number of things but i particular I would run the show switch stack-ports and see if there are any errors. Could be a bad connections(maybe try an reseat each connector on the back of the stack
Maybe this would be a good start by checking those cables by disconnecting and then connect them one at a time.
if you do show switch do they report the same firmware on all switches?
You might want to call into the GTAC so we can assist. I wanted to start you off with something to check.
Ifyou run the command dir Dmp and see dmp files then I would contat the GTAC and WE can assist you.
You can feel free to use my name Jason and I can try to assist.
Here are some files to collect before calling into the GTAC so you can have everything prepared to moving forward to addressing your issue
look for this first:
dir Dmp (This shows all of the files that are hidden with a doing a dir)
and then type: .
-Copy Dmp tftp://x.y.z.w/name.z will bundle all of the files from all of the units into one file.
-Show Support
-To collect the Current.log
copy logs/current.log tftp://192.168.0.1/current.log
Manuel_Pineda
Hi Jason,
I will test the cables today during the night (in a maintenance window). I will disconnect and connect the stack configuration cables one by one in order to be sure that they don't have problems.
Also, I will change the power cable.
Acording to the info with the "show switches", this is the display:
IDF_P4(rw)->show switch        Management   Preconfig   Plugged-in        Switch             Code
Switch    Status     Model ID    Model ID          Status            Version
1      Mgmt Switch  B5G124-48P2 B5G124-48P2 OK                    06.71.02.0008
2      Stack Member B5G124-48P2 B5G124-48P2 OK                    06.71.02.0008
3      Stack Member B5G124-48P2 B5G124-48P2 OK                    06.71.02.0008
4      Stack Member B5G124-24   B5G124-24   OK                    06.71.02.0008
So, I assume is the same version.
Meanwhile I already extracted the files with the copy command.
I really don't know what the GTAC's phone number is. Please, can you provide me that information?
Thank you so much for your help.
Regards,
Manuel Pineda.
Photo of Drew C.
Drew C., Community Manager
  • 37,322 Points 20k badge 2x thumb
Hi Manuel,
Contact information for GTAC can be found here: http://www.extremenetworks.com/support/contact
Photo of An-Tin Liu
An-Tin Liu
  • 478 Points 250 badge 2x thumb
How to slove the probilem ?
Photo of Santiago Gallardo
Santiago Gallardo
  • 60 Points
Hi everyone,
I had that problem and I realised that it was caused by one unit rebooted.
(Edited)
