application analytics engine "127.0.0.1 does not support network services dashboard"
  • Question
  • Updated 1 year ago
  • Answered
Hello,
We just implemented an analytics testbed in netsight 7.0.5.12.  If I look at the network services in the analytics dashboard tab, it reports the data properly.  However, if i create a report using "Network Service Response Time Data" within report designer and try to view the report, it gives me the pop-up message "127.0.0.1 does not support network services dashboard".
Is this by design?  Thanks much.
Photo of Joshua Puusep
Joshua Puusep
  • 2,264 Points 2k badge 2x thumb
Posted 2 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,306 Points 20k badge 2x thumb
Hi Joshua.
I've 7.0.6 running and see the same issue.
I don't think that this is by design, if the report is available it should work and show the correct data.
Cheers,
Ron
OK it works sometimes but it's very inconsistent - it works better if you never use F5 to refresh the whole screen (at least in my setup) - only use the refresh icon in the GUI.
Which web browser do you use ?
Joshua Puusep
I typically use Firefox, occasionally chrome.  I haven't been able to successfully load it yet in a report, but I'll keep trying and bring it up with GTAC.  Thank you for testing.
Photo of Vesna
Vesna
  • 136 Points 100 badge 2x thumb
Hi Joshua,
did you find solution for this problem?
Tnx!
Joshua Puusep
Honestly I got caught up with other projects and this fell off my radar.  I just tested it in chrome and as Ron mentioned, it's sporadic.  I'll open a case with GTAC now and provide an update.
Photo of Dudley, Jeff
Dudley, Jeff, Employee
  • 914 Points 500 badge 2x thumb
Hi Joshua,
I have the case and investigating the issue now.  Thanks
Jeff
Joshua Puusep
FYI, The case has been handed off to engineering, so it looks like we are waiting on a GA release to fix the issue.
Joshua is correct.  Hope to have some additional detail soon.
