Apply ACL to ISL port
  • Question
  • Updated 3 weeks ago
I want to apply ACL to VDX ISL port.
However, the following error message occurs when applying:
Bottom_SW1(conf-if-fo-1/0/49)# ip access-group Test_ACL out
%% Error: Edgeport configurations are not allowed on ISL ports.
Shutdown interface to apply such configurations.
The interface can be applied by shutdown. (and no shutdown)
Does access-group work in this case?
Thanks,
KYUNGCHAN.
Photo of kyungchan tae
kyungchan tae
  • 130 Points 100 badge 2x thumb
Posted 4 weeks ago
Photo of Jason Howlett
Jason Howlett, Employee
  • 102 Points 100 badge 2x thumb
ACL's  should be applied on edge ports not on ISL ports
Photo of Yulia Abitbul
Yulia Abitbul, Employee
  • 378 Points 250 badge 2x thumb
Hi KYUNGCHAN,
You can shutdown interface, disable ISL and apply ACL
ACLs are not allowed on ISL links,
Best Regards,
Yulia
