Appreciate if someone can explain clearly the use case of command "enable ospf mpls-next-hop " & "enable iproute mpls-next-hop".
  • Question
  • Updated 2 months ago
  • Answered
Photo of Ronie Singh
Ronie Singh
  • 144 Points 100 badge 2x thumb
  • Happy
Posted 2 months ago
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 13,516 Points 10k badge 2x thumb
you'll typically use "enable iproute mpls-next-hop" for L3VPN, imho.
This command will tell the router to prefer the MPLS LSPs rather than the IGP routes for entries that are learnt by both.
Here's an example:
PE2.28 # sh iproute
mp 192.168.255.40/32 15.0.210.1 1 U--D---um-L-- vl210 0d:4h:39m:53s
#oa 192.168.255.40/32 15.0.210.1 22 UG-D---um---- vl210 0d:4h:41m:51s
PE2.29 # enable iproute mpls-next-hop
PE2.30 # show iproute
#mp 192.168.255.40/32 15.0.210.1 1 U--D---um-L-- vl210 0d:5h:3m:30s
oa 192.168.255.40/32 15.0.210.1 22 UG-D---um---- vl210 0d:5h:5m:28s
The other command, "enable ospf mpls-next-hop" is to tell ospf to use an MPLS LSP to reach the destination, when available.
Ronie Singh
Hi Grosjean,
Thank you for your explanation and really appreciate it.  As per following snippet, can I confirm the path to PE2 is preferring via OSPF even though there is mpls ldp for the same destination ?
Does it mean the forwarding will be via pure L3 instead of labeling ?
PE1 # show iproute 172.17.80.55/32
Ori  Destination        Gateway         Mtr  Flags         VLAN       Duration
 mp  172.17.80.55/32    172.17.70.125   1    U--D---um-L-- PE2-Via-P1 2d:18h:36m:2s
#or  172.17.80.55/32    172.17.70.125   16   UG-D---um--f- PE2-Via_P1 2d:18h:36m:2s
Thanks.
  • 13,414 Points 10k badge 2x thumb
in your example, the "#" is important, this is the entry in the FIB. Here, it's using pure L3.
