AP's with link problems
  • Question
  • Updated 11 months ago
  • Doesn't Need an Answer
In our dashboard I noticed that ther where AP's with link problems. However there are no problems. How can I clear this messages ?
Photo of Johan Hendrikx
Johan Hendrikx
  • 2,900 Points 2k badge 2x thumb
Posted 11 months ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 44,984 Points 20k badge 2x thumb
Hi Johan,
you'll get a "link problem" error if the port isn't running 1G so i.e. if you've the APs connected to a 100M only switch or if autosensing isn't working.
-Ron
Johan Hendrikx
Ap's are connected to a 100 Mb port. Autosensing is working
(Edited)
Photo of Nathiya Munuswamy
Nathiya Munuswamy, Employee
  • 1,706 Points 1k badge 2x thumb
Hi Johan,
What is the firmware version on the controller? Please check the below KB article,
https://gtacknowledge.extremenetworks.com/articles/Solution/AP-s-are-listed-in-the-AP-s-with-uplink-...
Regards,
Nathiya M
Johan Hendrikx
firmware version is 10.31.03.001.  AP's are connected to a 100 Mb port.
OK then it's normal if the APs are connected via a 100Mb ports.
I'm not aware of any way to clear that alarm.
