Are the L3 extreme switches compatible with Variable Length Subnet Masking (VLSM)?
  • Question
  • Updated 6 months ago
  • Answered
Photo of Obernan Cavalcante
Obernan Cavalcante
  • 134 Points 100 badge 2x thumb
Posted 6 months ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,086 Points 10k badge 2x thumb
Yes, you can use standard CIDR notation (eg, 10.0.20.1/23) when configuring IP addresses on the switch..
Obernan Cavalcante
Ok, thanks for reply.
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 12,742 Points 10k badge 2x thumb
the VLSM idea is from times back when classful IP routing was used. Old routing protocols did not send a subnet mask with the network address. But all modern routing protocols (including RIPv2 which is not really modern) include a network mask (or prefix length) and fully support CIDR (classless inter-domain routing) which includes all the features associated with VLSM (variable length subnet masks).
Extreme switches and routing protocols support classless IP routing by default.
Thanks,
Erik
Obernan Cavalcante
Ok, very thanks for explanation.
