Are there OIDs to monitor all stack nodes of a Summit stack xith X440-G2?
Marco_Pfiffer
Hi Extreme community,I try to monitor a Summit Stack contaning 4 nodes. All nodes are X440-G2 switches. The monitoring sytem can either use SNMP or SHH CLI commands to gather informations. My problem is that I like to get informations about the status of each node, not only the master. Any ideas how to realise that?Thanks for your help!
Best regards,Marco
8 REPLIES 8
Alexandr_P
Valued Contributor
Hello, all!
Tell me please, what kind of graphical MIB interpreter do you use?
For not so long to look for the right OID
Asking Partners which isn't use ExtremeManagement )
Thank you!
I use the SNMP Tester from Paessler. It is free and works fine.
With large request (walks) it can hang. But normally perfect.
Thank you!
I use the iReasoning MIB Browser and a tool called Paessler SNMP Tester. Both work fine and are freeware.
