Aruba model 320 ap's cannot draw enough POE from SSA
  • Question
  • Updated 2 years ago
  • Answered
Aruba AP model 320 goes into low power setting when connected to POE on SSA.  I set the inlinepower port capability to 8023at for 34w but I see no difference in the usage number. This is happening with several aps. on different ports.
SEC_Core_SSA(rw)->show port inlinepower ge.1.15
Port     Type          Oper             Admin  Priority Class Power Power PD
 Power  Power
         (truncated)   Status           Status                Limit Usage Type
 Capab- Capab
                                                              (mW)  (mW)
 ility  Select
ge.1.15                delivering power auto   low      4     34000 6000  8023
 8023at 8023at
SSA  Fw: 07.71.02.0005
Is there another setting I could use to force the port to more power?
thnks in advance
walt
Photo of Walt Witkowski
Walt Witkowski
  • 416 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Roger Green
Roger Green
  • 200 Points 100 badge 2x thumb
how many power supplies in the SSA ?
Photo of JAMES WIEDEL
JAMES WIEDEL
  • 780 Points 500 badge 2x thumb
Walt,
There are 2 commands you need to do to give your access point the ability to use "at" power.
Looks like you did the first but probably didn't realize you needed the second:
set port inline ge.1.15 type "power hungry AP" powerlimit 34000 capability 8023at
set lldp port tx-tlv poe ge.1.15
Power is negotiated via lldp at a low level and by default is not enabled on S-series
as well as K-series by default.   I have been told that it is OK to enable it on all ports.
"power hungry AP" is just a descriptive string, like the ifAlias.     A few (not many) phones require the extra power as well as some (not all) PTZ cameras (Pan Tilt Zoom cameras).
Hope that helps!
    James
Photo of Mike D
Mike D, Alum
  • 3,852 Points 3k badge 2x thumb
Hi Walt,
Each of the following are necessary:
*Upgrade the S-series to 8.42.04.x – released August 2016
As of 8.41 f/w the mdi tlv's and most 802.11ac grade AP interop functional.  8.42 code has some tuning to clear all known interop problems.
*Set lldp port tx-tlv poe ge.1.15 Allows L1 criteria communication
*Set lldp port tx-tlv med-poe ge.1.15 Allows power value negotiation - the most recent fixes (*8.42.etc) have been in this area.
In line with the suggestions added up to this point - but additional code level and command required.
That should work.
Regards,
Mike
