Attenuation Setting for WS-AI-DE07025 external antenna
  • Question
  • Updated 1 year ago
  • Answered
We have installed a number of 3935e APs with WS-AI-DE07025 sector antennas attached to them. Does anyone know what the attenuation setting should be under the professional installation tab for installations using the approximately 4.5 foot (1.3 m) cables supplied with the antenna?
Thank you
Photo of Chris Taylor
Chris Taylor
  • 826 Points 500 badge 2x thumb
Posted 1 year ago
Photo of Darrel Rhodes
Darrel Rhodes, Employee
  • 1,186 Points 1k badge 2x thumb
Hi Chris,
I've not easily been able to find out the cable type supplied with the antenna, do you have access to the cables to find out the type?
Many thanks,
Darrel.
Chris Taylor
I received an e-mail from Yury on this subject
When you do Professional Installation and choose the right antenna  , it includes the cable attached to this antenna and certified for that . Only if you have additional extension cable which is not included to the antenna package , then you need to calculate the attenuation
Thanks Yury
