Authenticated Registration by RADIUS problem
  • Problem
  • Updated 2 years ago
  • Solved
I've configured a captive portal for authenticated registration. When I check the credential against the local DB, it works fine. I have a RADIUS server, which we use to authenticate users for EAP-PEAP and it works also fine. But, when I try to use it for checking the credential entered for authenticated registration, the RADIUS server returns an Access Reject answer. Does somebody has an idea, where could be a problem?
Photo of Gabriel Bagita
Gabriel Bagita
  • 550 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,306 Points 20k badge 2x thumb
Check the RADIUS server log to see the reason for the reject.
Gabriel Bagita
I'd like to do it, but I can't. I have no access.
Photo of Keene, Scott
Keene, Scott, Employee NMS/GTAC
  • 1,388 Points 1k badge 2x thumb
You will need access the the RADIUS server's event log to tell.
Hello,
It is likely that the RADIUS server's RADIUS policy is missing the needed authentication type or perhaps a Policy Condition is not matching.  The Event log should give a reason for the Reject.
Regards,
Scott Keene
Gabriel Bagita
Hi Scott,
your recommendation has helped to me. There was a problem in the Policy. It it is working correctly now.
Thanks
Very nice!  I am glad it is working now.
You're welcome.
-Scott
