Auto-provision
  • Question
  • Updated 4 years ago
  • Answered
Create Date: Jan 16 2013 1:00PM
We testing the auto-install feature from extreme. We have yet to make it work with our DHCP platform but we are working on that.
I was wondering if any of you have done this and get it to upgrade to a certain release in the auto-provisioning script ?  Is that even possible ?
(from Andreas_Larsen)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 4 years ago
Create Date: Jan 21 2013 1:34AM
I did play a little bit with the autoexec.xsf and the default.xsf and I can say that it works as intended.
However, because of the 500 seconds time limit for execution of these scripts, the firmware upgrade usually took longer than that and the script execution eneded in the middle of the firmware upgrade process.
The firmware was upgraded but nothing else in the script happened. A possible workaround would be to put every possible command before performing the upgrade.
Haven't worked with DHCP and auto-provisioning yet so I can't really help with that.
(from Eugen_NAIMAN)
