Automatically delete users/devices from registration portal
  • Question
  • Updated 2 years ago
  • Answered
Hi everyone,
is it possible to automatically delete users and devices from the list in registration portal when the defined access time is exceeded?
Stephan
Photo of Stephan
Stephan
  • 484 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Keene, Scott
Keene, Scott, Employee NMS/GTAC
  • 1,562 Points 1k badge 2x thumb
Hello,
You can delete registered users and their devices from inside the MAC Registration Administration web interface.
There is an article on a similar topic below, on increasing the device count, but the article will tell you how to get to the web interface I am referring to...
https://gtacknowledge.extremenetworks.com/articles/How_To/NAC-How-to-increase-the-maximum-number-of-...
To do this automatically, please look at the setting in the Captive Portal Configuration: Delete Expired Users". This should trigger (if selected) when the registration expires.
 Is this what you are looking for?
Regards,
Scott Keene
Extreme GTAC
(Edited)
Photo of Stephan
Stephan
Hi Scott,
thank you for your answer. I had a look in the settings you mentioned. Unfortunately the setting "Delete expired Users" is missing in Guest Registration. But this is what we need. Also I can't find any option to automatically delete devices.
Regards,
Stephan
