Automatically upload switch configuration daily
  • Question
  • Updated 4 years ago
Create Date: Mar 26 2013 5:01PM
I can get my ExtremeWare switches to automatically upload their configs each night to a tftp server I have setup.  I cannot get my ExtremeXOS switches to do the same.  There doesn't seem to be the same commands on the XOS switches.
I am trying to use both version 12 and 15 of XOS firmware on switches like X460's X440's X250e's X450e's etc.
BTW: The command I use on Extreme 200 and 300 switches is below -
upload configuration /configs/.cfg every 0:59
Does anyone know what the command would be to make a XOS switch upload a config each night?
(from statonar)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 4 years ago
Create Date: Mar 26 2013 7:01PM
hello statonar
You are correct but what you can do is set up a UPM profile that has the upload command.
Then you can set up a timed interval so that the profile runs every 24 hours.
Hope that helps let me know if you have any other questions.
P
(from Paul_Russo)
Create Date: Mar 28 2013 8:03PM
Hey thanks, that worked perfectly.  Never knew the power of making upm profiles before this.
(from statonar)
Create Date: Mar 28 2013 8:37PM
Great to hear.  UPM and scripting in general allows you to do a lot of automated processes.
Continue to post online and we will do what we can to get you the right answers.
P
(from Paul_Russo)
