Avaya Power cord matrix needed
Peter_Kisthard1
Hi All, in April the Avaya Switches will moved to Extreme Pl. The new part codes are the "A" Version without power cords. For EU in the past we had the "B" version (PC included). Who can help me with a power cord matrix for the Avaya Switches because we have to order it now separately? Thanks Peter
4 REPLIES 4
Nicolas_SIMONS
Hello Peter,
I am a bit late, but it can help someone else.
Are you looking for a matrice like this?
https://drive.google.com/open?id=1GgQ9d1k43VDlRCKEgra02p1zYlyvMDQe
Peter_Kisthard1
Hi Drew,I´am looking for cords for e.g.: AL1905A09-E6 AL1905A19-E6 AL1905A21-E6
this are the new product codes for the Avaya Equipment that will be moved in the extreme pricelist
Thanks
Peter
Drew_C
Valued Contributor III
Hi Peter,
What are the plug types on those? C13, C15, and C19 are most common. How about the supply side? C14 is pretty common in data center PDUs.
Drew_C
Hi Peter,
Extreme's power cord matrix can be found here: https://www.extremenetworks.com/product/powercords/
What plug types are you looking for?
