AVB and Cobranet
  • Question
  • Updated 3 years ago
  • Answered
I want to place a cobranet device on exteme switch (summit x440) that is licensed with avb and is edge switch on avb network. I created vlan cobranet and disabled avb, tagged cobranet to core switch (summit x460). Will there any issues with layer 2 traffic between avb and cobranet due to clocking?
Photo of mike delaney
mike delaney
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Chad Smith
Chad Smith, Alum
  • 5,660 Points 5k badge 2x thumb
Mike,
Will the AVB and Cobranet VLANs ever share the same port in the network?  When AVB is enabled, AVB traffic is prioritized over all other traffic, so if the two technologies share a port there is the possibility that AVB traffic could cause sync issues on the Cobranet network.
If the two networks never share the same physical ports, I believe it should work.  The only concern would be making sure that Cobranet traffic does not overwhelm the switch CPU for some reason and interfere with AVB control traffic.
mike delaney
Thanks, I will run seperate fiber from x460 to x440 and tag to cobranet vlan.
