AVB disabled after reboot
  • Problem
  • Updated 1 week ago
  • In Progress
  • (Edited)
I have a X440-G2-24t-GE4, I have installed the AVB licence using the CLI, then set up a IP for using the web browser chalet control. I enabled the AVB ports in chalet and clicked save. but when the switch is power cycled/rebooted the AVB ports are disabled upon reboot. i have to go back into the AVB config and enable them again.
any clues as to why this is happening?
Photo of Jeff Woodford
Jeff Woodford
  • 80 Points 75 badge 2x thumb
Posted 3 weeks ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 51,226 Points 50k badge 2x thumb
Try....
- enable ports via chalet
- save config via CLI
.... does that work ?
What software version is running and what web browser is used, have you tried it with another PC/browser.
Jeff Woodford
I tried a different browser and same issue. config not saved via chalet after reboot.
I found this from the Biamp website and used the CLI and Putty:
To enable AVB on all ports, enter the following commands:
disable flow-control rx-pause ports all
disable flow-control tx-pause ports all
enable avb
enable avb port all
disable edp port all
save configuration
this worked and th config was saved after a reboot.
I have to say the Extreme Networks website and support documentation and user guides are a nightmare to find the right information and massively over complicated
