B2G124-48P After Firmware upgrade ERROR
  • Question
  • Updated 2 years ago
  • Answered
I did a Firmware Upgrade form 1.01.25
to  4.02.19.0008
 the Upgrade i did it over TFTP with no errors.
After reboot i get this on Serial Console:
This goes hours and nothing more happens.
I cant connect over LAN.
Enterasys B2-Series Boot Code...
SDRAM Circuit Test of 255MB
100%
Version 01.00.48 10-21-2010
Computing MD5 Checksum of operational code...
Select an option. If no selection in 2 seconds then
operational code will start.
1 - Start operational code.
2 - Start Boot Menu.
Select (1, 2):
Operational Code Date: Thu Dec 18 11:38:00 2014
Uncompressing.....
                       50%                     100%
Attaching interface lo0...done
Adding 60405 symbols for standalone.
SOC unit 0 attached to PCI device BCM5697_B0
SOC unit 1 attached to PCI device BCM5697_B0
SOC unit 2 attached to PCI device BCM5697_B0
SOC unit 3 attached to PCI device BCM5697_B0
SOC unit 4 attached to PCI device BCM5670_A1
Adding BCM transport pointers
Configuring CPUTRANS TX
Configuring CPUTRANS RX
st_state(0) = 0x0
st_state(1) = 0x2
(Unit 1)(STACK: master on 0:11:88:2a:73:29 (1 cpu, 5 units)
STACK: attach 5 units on 1 cpu
This switch is manager of the stack.
Username:osapiFree_track(1976):LOG_ERROR(0)
Task ID:    0x8756f30
Task Name:  dot3ad_lac_task
PC:         0x10b9db4
PendQ:      0x873cd94
SP:         0x8756950
0x10b9db4: qJobGet (0x10b9bd8) + 0x1dc
0x10ab424: msgQReceive (0x10ab07c) + 0x3a8
0x518bc: osapiMessageReceive (0x516d0) + 0x1ec
0xb11a8: dot3ad_lac_task (0xb0fc8) + 0x1e0
0x10b7750: vxTaskEntry (0x10b76e8) + 0x68
<160>Jan  1 00:00:49 0.0.0.0-1 UNKN[141913904]: osapi.c(1984) 217 % File:dot3ad_migrate.c Line:300 Component:10
<160>Jan  1 00:00:49 0.0.0.0-1 SIM[141913904]: osapi.c(1985) 218 % Error(0x5d2d524)
100%
Select (1, 2):
Uncompressing.....
                       50%                     100%
st_state(0) = 0x0
st_state(1) = 0x2
Task ID:    0x8756f38
PC:         0x10b9db4
PendQ:      0x873cd9c
SP:         0x8756958
<160>Jan  1 00:00:48 0.0.0.0-1 UNKN[141913912]: osapi.c(1984) 233 % File:dot3ad_migrate.c Line:300 Component:10
<160>Jan  1 00:00:48 0.0.0.0-1 SIM[141913912]: osapi.c(1985) 234 % Error(0x5d2d4b4)
100%
Select (1, 2):
Uncompressing.....
                       50%                     100%
st_state(0) = 0x0
st_state(1) = 0x2
Username:osapiFree_track(1992):LOG_ERROR(0)
Task ID:    0x8756f40
PC:         0x10b9db4
PendQ:      0x873cda4
SP:         0x8756960
<160>Jan  1 00:00:48 0.0.0.0-1 UNKN[141913920]: osapi.c(2000) 249 % File:dot3ad_migrate.c Line:331 Component:10
<160>Jan  1 00:00:48 0.0.0.0-1 SIM[141913920]: osapi.c(2001) 250 % Error(0x5d2d024)
Photo of Choussein Kara
Choussein Kara
  • 120 Points 100 badge 2x thumb
Posted 2 years ago
Photo of George, Chris
George, Chris, Employee
  • 982 Points 500 badge 2x thumb
The upgrade of firmware you made was a significant jump in code revisions.  It's possible something is corrupted in the configuration.  My first suggestion would be to factory default the device.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-To-Restore-Securestack-to-Factory-Defa...
If Factory defaulting the device does not resolve the issue, My assumption would be that the device is fault.
Unfortunately, if that is the case there isn't a whole lot that can be done.
This product went End Of Sales:6/30/2008 and End of Service: 6/30/2013 so there is no active warranty or ability to have the unit repaired.
Choussein Kara
Thx !!!!
It helps me.
My Switch is Working Normal !!!
