B5 detects unsupported pluggable module
  • Question
  • Updated 3 years ago
  • Answered
Hello Guys,
Our customer is complaining about newly delivered B5-series switches. He puts 10G SR SFP+ Module (10 Gigabit Ethernet SFP+ module, 850nm, MMF 26-300m link, LC connector, Extreme p/n: 10301) and gets following warning on console:
Dec 9 13:59:33 10.10.79.82 EDB[190093792]: edb_bxs.c(1985) 32 This is from manager 1 % Unsupported pluggable module detected on ge.2.47
Switch was factory delivered with 6.71.03.0025 firmware; update to the newest 6.81.06.0002 version didn't help.
According to RN module should be detected properly (?)
Any ideas ?
REGARDS
Robert
Photo of Robert Zdziebło
Robert Zdziebło
  • 646 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Alex Morrissey
Alex Morrissey, Employee
  • 862 Points 500 badge 2x thumb
Hello Robert,
Can you verify the model of the B5 you are using this optic in?  The 10gig capable models should start with a B5K where the 1gig only models are B5G
The 10301 optics should be supported on the B5's however it appears you are plugging the optic into a 1gig port.  The "ge" of the "ge.2.47" identifies the port in that error message as a gig port.  10gig ports will have a "tg" in the first section of the port string.
Regards,
Alex
Photo of Curtis Parish
Curtis Parish
  • 3,332 Points 3k badge 2x thumb
The 10G ports (tg)  are  49 and 50 on a B5K 48 port .  I think they are 25 and 26 on a B5K 24 port
Robert Zdziebło
The model is B5K125-48. I'll check 10g port tomorrow, thank you for suggestions.
Robert Zdziebło
Modules were inserted into the slots labeled as '10G'
Curtis Parish
Your original post said 10G  module was inserted into slot 47.  Slot  47 is not a 10G slot.     Only 49 and 50 are 10G.
Robert Zdziebło
Yes, but customer said he also tried modules on all four sfp+ slots, including 10G ones.
Curtis Parish
There are only two SFP+ slots on a B5K.  47 and 48 are combo  RJ45/SFP slots .   Can you have them plug the transceiver  into the bottom right slot and   post the results of the following commands?
show port status tg.*.*
show port status ge.*.47
show port status ge.*.48
(Edited)
Robert Zdziebło
Anyone ever tested these 10310 optics on B5 series with success ?
Robert Zdziebło
I have put these 10301 modules in B5K's 25 and 26 port, plugged LC-LC patchcord connecting both ports. I know it doesn't make any sense in real life, but I wanted to check how the modules behave and I don't have any other 10g switch. Both links are up and here is the cli output:
Robert Zdziebło
and another:B5(rw)->show logging buffer
Dec 15 11:49:34 0.0.0.0-1 EDB[174803304]: edb_bxs.c(1935) 23 %% Unsupported pluggable module detected on tg.1.25
Robert Zdziebło
does it mean that modules are working or not ?
Robert Zdziebło
Note: I am testing it on B5K-125-24P2 switch, not on B5K125-48 switch as mentioned originally (thus tg port numbers are different).
Curtis Parish
It appears to be working.   The following is for  a previous version of firmware but indicates the module was working even with the error.  https://community.extremenetworks.com/extreme/topics/c5_b5_f_w_6_71_03_0025_issuing_unsupported_plug...
Robert Zdziebło
Thanks for your help, Curtis. I have no possibility to check it under normal conditions, but the modules behave as they were working (?).
