B5 or C5 Temperature monitoring
  • 2
  • Question
  • Updated 4 years ago
  • Answered
Hi, is there a way to query the ambient temperature of a B5 or C5 switch with SNMP? The MIB cabletron-environment works perfectly for S4 and S8 cores, but not for B5 or C5 switches. Thanks a lot! Best Regards,Thomas
Photo of Thomas Kassirra
Thomas Kassirra
  • 80 Points 75 badge 2x thumb
Posted 4 years ago
  • 2
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 51,328 Points 50k badge 2x thumb
Hi Thomas, AFAIK there is no way to query the current temperature but you'd enable SNMP traps to get an alarm as soon as the chassis is getting too hot.
So here my notes from a test I've done last year with a D2 and Netsight ....
- configure the switch to enable trap forwarding to IP 10.12.0.22
set snmp targetparams publicpara user public security-model v1 message processing v1
set snmp targetaddr publictrap 10.12.0.22 param publicpara taglist publictraptag
set snmp notify publictrap tag publictraptag
- enable SNMP for system temperatur traps
set system temperature trap enable
- test = force the trap = set temperatur threshold to 1% = fan will go max
set system  temperature overtemp-threshold 1 trap enable
- turn it back to normal
set system  temperature overtemp-threshold 100 trap enable
example of the Netsight trap (Netsight version 6.0 early release)
