Backup Summit/BD switches using FTP/SCP
  • Question
  • Updated 2 years ago
  • Answered
Hello, I am trying to configure a routine backup for the summit and black diamond switches on my network.
i can tftp to other unsecured servers but the server to host the backup configurations is secured.
SCP is giving me the error below;
CHOU-JCE-SW04.1 # scp2 vr "VR-Default" admin@172.24.X.X/backup/ex_switches:config primary.cfg
Download  to /config/primary.cfg on switch
Connecting to 172.24.X.X/backup/ex_switches:config...
ssh: 172.24.X.X/backup/ex_switches:config: Name or service not known
Couldn't read packet: Connection reset by peer
while there is no option for FTP
Photo of Mofinyinfoluwa Oyegunle
Posted 2 years ago
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,714 Points 10k badge 2x thumb
Hello Mofinyinfoluwa,
The format used for SCP is "scp2 <user>@<scp_server>:<remote_file> <local_file>"
I see you have a : between switches and config (ex_switches:config). Was this intended or should it be a "/". Changing that might resolve your issue.
Let us know if it works!
Hi Patrick,
When i try to use /, it says the command is incomplete. it appears you can only use scp to retrieve files from a server and not put files.
CH.2 # scp2 vr "VR-Default" admin@172.24.154.235/mnt/backup2/mpbn_backup primary.cfg
%% Incomplete command
CH.2 # scp2 vr "VR-Default" admin@172.24.154.235/mnt/backup2/mpbn_backup primary.cfg?
  <user@host:file>  User @ remote host or IP address with remote file name
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 13,772 Points 10k badge 2x thumb
You are missing a colon between the IP address and the file path.
scp2 vr "VR-Default" admin@172.24.154.235:/mnt/backup2/mpbn_backup primary.cfg
Hi Erik,
Thanks, it works using the format below for uploads,
"scp2  <local_file> <user>@<scp_server>:<remote_file> "
C4 # scp2 vr "VR-Default" primary.cfg admin@172.24.154.235:/mnt/backup2/mpbn_backup
Upload /config/primary.cfg to
Connecting to 172.24.154.235...
airtelmpbn@172.24.154.235's password:
Uploading /config/primary.cfg to /mnt/backup2/mpbn_backup/primary.cfg
/config/primary.cfg        100%  289KB 289.0KB/s   00:00
Is there any way to automate this process, I have a bit over 50 switches on my network?
Photo of Tripathy, Priya Ranjan
Tripathy, Priya Ranjan, ESE
  • 2,306 Points 2k badge 2x thumb
I can see after inserting the : in between the ip address and file path it is working now. Anyway in the future for further reference you can always have a look at below article link which says the correct procedure of implementing this:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-upgrade-EXOS-using-SCP/
(Edited)
