Backup wireless controller fail somtimes for some SSID
  • Problem
  • Updated 3 years ago
  • Solved
Hi all,
I have setup of 2 wireless controllers, 5 SSID and 200 APs. 4 Topologies are bridged at EWC and one at AP. Everything is going and working well as all access points are active in the main wireless controller. But when some APs move to be active on the backup controller some SSIDs (bridged at EWC) don't work well sometimes for some users while other SSIDs keep working well.
I checked the path between two wireless controllers and all Topologies are reachable and synchronized.
I am using C5210 and software   09.21.06.0006 for both controllers
Anyone have an idea what could be wrong?!
Thanks in advance,
Husam
Photo of Husam
Husam
  • 1,272 Points 1k badge 2x thumb
Posted 3 years ago
Photo of Husam
Husam
Official Response
Thank you. It is solved. it was miss-configuration related to default gateway of some topology.
Best regards
