Bandwidth Control per WLAN Service
  • Idea
  • Updated 2 years ago
Anyone else interested to see the Bandwidth Control feature to work not only per client but also per WLAN service (SSID).
That would limit the max upload/download on the whole WLAN service i.e. all clients on that SSID couldn't exceed 50Mbps/25Mbps.
If someone from engineering could tell whether that could be (easily) implemented.
Because if there is no way to do it because of controller limitations I'd pass on opening a feature request.
Thanks,
Ron
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 51,288 Points 50k badge 2x thumb
Posted 2 years ago
Photo of Bastian Sprotte
Bastian Sprotte, Employee
  • 1,700 Points 1k badge 2x thumb
Ron,
if the Topo has the breakout on the controller, you might can control the traffic on the incomming switch port/vlan where the traffic will be switch/routed.
an Topo with Bridged@AP we will not able to control the traffic as distributed AP system and rate limit an SSID.
regards
Bastian
Hey Bastian,
I should have shared more infos, the thing is that there is more then one branch and they all will us the same topology = breackout with the same VLAN ID on the controller.
So I don't think that I'd control it on the device (switch/router) that connects the controller = I can't limit it per branch as they use all the same topology/subnet.
BR,
Ron
I've forgot to share the issue behind the idea/request.
Setup: Branch office with 2 SSIDs (staff & guest), topology must be bridge@EWC.
There is only limited bandwidth on the uplink from the branch to the HQ and if a lot of guests connect they took a lot of bandwidth and the staff doesn't get the bw that is needed.
The function would limit the bw on the guest SSID to i.e. 50% of the uplink so the staff has enough bw left to work with.
Or any other idea to throttle the guest bw.?
Thanks,
Ron
Photo of Andre Brits Kannemeyer
  • 5,330 Points 5k badge 2x thumb
The rate limiting will need to be applied to the Topology in this case....
Would be nice to be able to rate limit the whole Top not just the individual Clients.
(Edited)
Photo of Chris Taylor
Chris Taylor
  • 816 Points 500 badge 2x thumb
It would be great to rate limit a topology or WLAN (SSID).  As a convention centre we could provide customers with a level of bandwidth to be divided up between their devices.  My topologies are all bridge@EWC but I have the ports trunked so rate limiting on the switch port would affect all WLANs
Photo of Steve Ballantyne
Steve Ballantyne
  • 5,806 Points 5k badge 2x thumb
I presently limit my wireless guests per-connection. But they could still gather up a lot of connections and gang up on my bandwidth. So yes, I could see how this would be useful. Limit the client connections using the usual means, but also put a cap on the whole dang' thing to prevent an overflow.
