Basic Policy Based ACL
  • Question
  • Updated 1 year ago
  • Answered
  • (Edited)
Hi there,
Can anyone explain to my why this basic ACL policy does not work?
This is using XOS 22.2.15 on an X450-G2.
I want to emulate Cisco behaviour of permitting what I want with an deny at the bottom.
# Permit
entry 1.1 { if { source-address 192.168.132.0/26; destination-address 192.168.249.202/32;} then { permit; count Permit;}}
# Deny Everything Else
entry 2.1 { if {} then { deny; count Deny;}}
The access list is applied to a VLAN as follows:
configure access-list Test vlan "Data" ingress
It seems to drop all packets, I thought policies were supposed to process top down with packets until they get a match?
Thanks,
Mark
Photo of Mark Lamond
Mark Lamond
  • 456 Points 250 badge 2x thumb
Posted 1 year ago
Photo of Nick Yakimenko
Nick Yakimenko
  • 2,476 Points 2k badge 2x thumb
if match any
Photo of Jarek
Jarek
  • 2,398 Points 2k badge 2x thumb
the last ACL, will block  all traffic including ARP, etc. on vlan ingress.
You should for example add before the last entry:
entry ARP { if match all {    ethernet-type 0x0806 ;
} then {
    permit  ;
and  so on...
Jarek
(Edited)
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 13,458 Points 10k badge 2x thumb
if you want to emulate an IPv4 router ACL, you should use a deny statement that denies IPv4 packets only:
entry 2.1 { if {source-address 0.0.0.0/0;} then { deny; count Deny;}}
Otherwise you will have problems with e.g. ARP as mentioned by Jarek.
Thanks,
Erik
Mark Lamond
Thanks for the replies folks, now working as expected and making a lot more sense.
We use a lot of ACL's and are moving from Enterasys/Cisco to Extreme so a lot to learn.
Thanks,
Mark
Hi Mark,
if you need to convert Cisco(-like) ACLs to EXOS you can try the IOS to EXOS ACL Convert Perl script. Simple IPv4 ACLs can be converted with E2X as well.
Thanks,
Erik
Hi Nick,
first a disclaimer: I did not test that my routing policies above really work...
My understanding is that "nlri any/X" without "exact" matches on any network with a prefix length of X or longer. Thus you can compose the policy to first deny the too-long prefixes, then allow the accepted prefix length range, and then deny anything not yet matched.
Example:
entry all_ipv6_05 {
  if {
    nlri any/49
  } then {
    deny
entry all_ipv6_10 {
  if {
    nlri any/20
  } then {
    permit
entry ipv6_out_15 {
  if {
    nlri any/0
  } then {
    permit
That method should work for IPv4 as well.
Thanks,
Erik
Nick Yakimenko
That is a very good idea, but it does not work as expected
Line 3 : Failed argument value 49 is invalid
First of all, first argument should be
nlri any-ipv6/49
Secondly, I tried to filter-out a /48 announces from uplink, so I modified first argument to a /47
Did a policy-refresh
Tried to disable and then re-enable the bgp-session, but still I can see /48 announcements from an uplink.
Thanks for testing. Sorry that it did not work. :-(
Nick Yakimenko
thank you very much for the solution!
That was my typo:
I applied the policy like this
configure bgp neighbor 2001:db8::1 route-policy in allv6-in
and (again!) forgot about address-family ipv6-unicast
now it works as expected
Great that it works!
Thanks,
Erik
