BD 8900-MSM128 console connection
  • 2
  • Question
  • Updated 3 years ago
  • Answered
Hi All,
I am trying to access to 8900-MSM128 module using console port. This console port is COM not RJ45 port.
I am using 2 adapters that shipped normally with switches from both sides (module side and my laptop side) I tried all the option using secure CRT but I could not get access.
Anyone had experienced this problem, is there a special adapter for this module.
Thanks in advance,
Husam
Photo of Husam
Husam
  • 1,272 Points 1k badge 2x thumb
Posted 3 years ago
  • 2
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,474 Points 10k badge 2x thumb
What setting are you putting into secure CRT? Are you using a USB to Serial converter? I know these may have been things you have checked but make sure you are using the correct com port and make sure the serial setting are set to the following:
Speed (Baud) = 9600
Data Bits = 8
Stop Bits = 1
Hope this helps!
(Edited)
Photo of Zubair Ahmad
Zubair Ahmad
  • 188 Points 100 badge 2x thumb
Husam,
I had similar issue, and couldn't get into console via using what's provided in the box.  ( I had COMM/usb to DB9 Male in the box).
I had to buy 'DB9 Female - DB9 Female', connect that to my PC and verify the COMM port number under 'My Computer>manage>Device>Com Ports',  worked fine.
After that I gave Ip address to MGMT port, and never had to use that DB9 anymore.
This may work for you as well.
ZA
Photo of Husam
Husam
Thank you Zubair, I could get access using this cable DB9 female - Female. I will give IP for mgmt vlan and forget this console port.
Regards,
Husam
