BD8800 Hitless Upgrade Questions
  • Problem
  • Updated 4 years ago
  • Acknowledged
  • (Edited)
I have done a half of hitless upgrade procedure of BD8800 with following "show switch" output after that.
Slot:             MSM-A                        MSM-B *
Current State:    BACKUP                       MASTER
Image Selected:   primary                      secondary
Image Booted:     primary                      secondary
Primary ver:      15.7.1.4                     12.5.4.5
Secondary ver:    15.7.1.4                     15.6.1.4
Config Selected:                               primary.cfg
Config Booted:                                 primary.cfg
Why there is no selected and booted config on MSM-A (backup, just upgraded)? Is it safe to do "run msm-failover" command on this situation?
Best regards,
Photo of Mrxlazuardin
Mrxlazuardin
  • 1,534 Points 1k badge 2x thumb
Posted 4 years ago
Mrxlazuardin
Any idea?
Photo of Drew C.
Drew C., Community Manager
  • 40,858 Points 20k badge 2x thumb
Hi Lazuardi,
I think at this point, it would be best if you can contact our GTAC team.
Mrxlazuardin
Hi Drew,
Of course, I have contacted GTAC and waiting for the solution. I post on this forum to see if somebody has same issue. Maybe there is some step by step with CLI output about successful BD8800 hitless upgrading procedure.
Best regards,
