BD8810 MSM-48c and MSM-g8x operating at same chassis?
  • Question
  • Updated 4 years ago
Create Date: Apr 9 2012 6:50PM
Hi there.
Can I operating MSM-g8x and MSM-48c at same chassis?
XOS Version : 12.3
Can do that?
(from Beomyong_Park)
Photo of EtherNation User
EtherNation User, Official Rep
  • 20,340 Points 20k badge 2x thumb
Posted 4 years ago
Create Date: Apr 10 2012 2:12AM
it should be possible.
Table 1: Required Minimum Software Versions
Manufacturing
Part Number Minimum Software Version
800230-00 ExtremeXOS 12.1.1 (or later)
800314-00 ExtremeXOS 12.1.4.2-patch1-3 (or later 12.1 release)
or
12.2.1 (or later)
CAUTION
"If you install an MSM-48c into a system with a primary MSM-G8X or MSM-48 running a software build earlier than
the required minimum ExtremeXOS version (see Table 1), your system may CRASH or not operate correctly.
A software upgrade may not be possible until the MSM-48c is removed."
--> see http://www.extremenetworks.com/librar...
M
(from matthias_mager)
