BD8k failover
  • Question
  • Updated 2 years ago
  • Answered
Hello, all!
Theoretical question:
BD8k with 2*MSM-48c with S-G8Xc cards.
What happend with data-ports on S-G8Xc cards when failover occurs?
Have an conflicting information:
1. When a modular chassis MSM/MM failover occurs, all of the ports in the chassis are under the control of separate processors which can communicate with the backup MSM/MM, so all ports continue to function.
Source - 16.1 User Guide
2. When you do a failover the current master slot will reboot causing all ports on that master slot to go down until the slot comes back.
Where is the truth? :)
Thank you!
Photo of Alexandr P
Alexandr P, Embassador
  • 12,042 Points 10k badge 2x thumb
Posted 2 years ago
Photo of Ron Huygens
Ron Huygens, Employee
  • 2,928 Points 2k badge 2x thumb
The statement 2 is definitely true. The complete MSM will reboot and that will also reload the S-G8Xc ports.
The statement 1 is true for all other ports on the I/O modules
Photo of Alexandr P
Thank you, Ron!
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,484 Points 10k badge 2x thumb
Hello Alexandr,
I may be wrong but the way #2 is worded it sounds like it is referencing a Summit stack. Especially since it is using Master slot as the terminology instead of MSM or Management Module. If it is indeed a stack then it would be true for a Stack only because the individual Node reboots.
Also, as Ron stated if there is a daughter card installed in one of the MSMs it could be referring to this as well because a reboot of that MSM will cause the daughter ports to go down temporarily.
Could you tell me what Page #2 came from out of the user guide?
(Edited)
Photo of Alexandr P
Hello, Patrick!
It's from here
https://gtacknowledge.extremenetworks.com/articles/Solution/Failover-Current-Backup-to-become-Master
Information is as for SummitStack so for BD.
Thank you!
Alexandr,
Yeah I think it is referring to a stack, even though it is not completely clear. I will see if I can update this article to make it more clear. Sorry for the confusion!
